Stock Concours sedan having Kick panels WITH Speaker covers - Chevelle Tech
  • 1 Post By Alwhite00
post #1 of 12 (permalink) Old Feb 25th, 20, 2:16 AM Thread Starter
Casey
Question Stock Concours sedan having Kick panels WITH Speaker covers
Okay I have an original brochure form 1968 that shows the 4 door Concours sedan showing the interior of the drivers side and it has a rectangle speaker cover that looks like it is of the sheet metal type with the small holes. It is flat and located on the front lower part of the kick panel and it has the pull handle for the fresh air vent.
That is to say I do not believe that that car had A/C as they deleted the fresh air vents if it was an ordered option correct?
In any event I am asking if anyone has seen these reproduced as I have not...?
They should fit a coupe?
I looked at many of the obvious sites and they all have the after market type of round speaker kick panels... Not the type I am looking for.
I may have to get a beater kick panel and try to devise a cut out and a cover then attempt my own.
If anyone has seen this or where I can get repros OR a template to cut your own I'd sure appreciate it.
1968 Malibu sport coupe to go with
my Barbie wife of the same year!
Capt Casey is offline
post #2 of 12 (permalink) Old Feb 25th, 20, 5:33 AM
Re: Stock Concours sedan having Kick panels WITH Speaker covers
Maybe post a picture from the brochure???
fishhead likes this.
67
70 (SOLD)
Alwhite00 is offline
post #3 of 12 (permalink) Old Feb 25th, 20, 8:19 AM
Shane
This one?
Name:	Screenshot_20200225-081756_Adobe Acrobat.jpg
fishhead is offline
post #4 of 12 (permalink) Old Feb 25th, 20, 3:19 PM Thread Starter
Casey
Originally Posted by fishhead View Post
This one?
Yes that those are the one's!
Maybe they just used the the same grills from the package try to install the 4 way speaker system and cut holes and added them?
I know they don't look pretty but they don't stick out like the newer ones seem to.
post #5 of 12 (permalink) Old Feb 25th, 20, 8:11 PM
Those are the grills for the factory or dealer installed 8-track stereo and/or Multiplex FM stereo set-up. They are for 4x6 speakers and are not the same as the 6x9 rear grills. You have to cut holes in the regular kick panels to install them.
I do not know if 68 Chevelle used the same grill as a 68 Camaro, but the 67-68 Camaro grills are reproduced I think. Try Heartbeat City Camaro parts on line. The rectangular shape and size would be the same (or very close), but the contour of how it fits the kick panel may be different. I do know that 67-68 Camaro grills are not the exactly the same as the Factory 67 Chevelle grills, but they can be made to fit and work in a 67 Chevelle with a little effort.
Good luck -
Jeff Helms
-65 Z16 Survivor (Red/black/white int.) (
-65 SS Convertible (Red)
-66 SS L34/M20 Survivor Coupe (Aztec Bronze) - 'Vintage Legend' Certified (
jeffschevelle is offline
post #6 of 12 (permalink) Old Feb 26th, 20, 11:30 PM Thread Starter
Casey
Good luck -
Thanks for the information. I'll have a look and see what is out there and measure up the kick panel area. I know the older speakers didn't have a huge magnet like the new one's do so they will not be able to handle a decent amount of power. I know there will be room in behind and yes if I have to cut then so be it.
I do some hunting now and for the 4x6 grills. Thanks again.
post #7 of 12 (permalink) Old Feb 27th, 20, 3:18 PM
Roman
I have a 67 Impala. Has the same appearing speaker grills in the same area of the kick panels. On mine it was a factory option.
sz0k30 is offline
post #8 of 12 (permalink) Old Feb 27th, 20, 10:17 PM Thread Starter
Casey
Hi Roman
Thanks for confirming this for me.
Do you recall if there was a room for the magnet behind the screen.
I am guessing there is not that much room or a pretty small magnet.
Guess what I am asking is was there sufficient room behind the plastic panel to mount the speaker
Did the speaker hang off the plastic kick panel or was there a mount attached behind the panel to the inside of the body?
Again
Casey
post #9 of 12 (permalink) Old Feb 28th, 20, 9:08 AM
Roman
Attached are 2 photos I took when I was working on my interior. They show exactly how it goes together. The speakers are aftermarket and they fit.
ID:	617894   Click image for larger version
sz0k30 is offline
post #10 of 12 (permalink) Old Feb 28th, 20, 10:31 PM Thread Starter
Casey
Hey thanks Roman.
Those are great pic's and they show I can use aftermarket speakers!
Great! Thank you so much!
post #11 of 12 (permalink) Old Feb 29th, 20, 9:26 AM
Roman
Hey Casey,
If you're looking for speakers check out this website:
Auto Electronics
sz0k30 is offline
post #12 of 12 (permalink) Old Feb 29th, 20, 7:53 PM Thread Starter
Casey
Thumbs up Re: Stock Concours sedan having Kick panels WITH Speaker covers
It Looks pretty good and those will slide in there nicely.
I am going to run a rebuilt gutted 68 AM Fm stereo from 68.
So it will be able to handle the higher output Ohms Etc.
Thanks for the link!
