1967 Inside door handle orientation - Chevelle Tech
  • 1 Post By jeffschevelle
post #1 of 6 (permalink) Old Feb 17th, 20, 10:50 PM Thread Starter
Finishing up the new interior and I bought the car completely blown apart and never saw the actual orientation of the interior door handle, I installed it like in the picture just because I thought thats the way it went from memory, just not sure if thats right or not?
CTblown67 is offline
post #2 of 6 (permalink) Old Feb 18th, 20, 4:23 AM
Talking Re: 1967 Inside door handle orientation
I think I recall a pretty funny debate about this several years ago that went on WAY too long.
Correct me if I'm INcorrect.
I believe it is supposed to point straight forward on a level plane.
David
davewho1 is offline
post #3 of 6 (permalink) Old Feb 18th, 20, 5:41 AM
From the 67 brochure.
67
70 (SOLD)
Alwhite00 is offline
post #4 of 6 (permalink) Old Feb 18th, 20, 6:33 AM Thread Starter
post #5 of 6 (permalink) Old Feb 18th, 20, 6:45 AM
FWIW, the 1967 El Camino Brochure shows them horizontal several times as well. But I would guess it is also a matter of preference, it isn't like you are modifying anything that isn't reversible correct? Mine are like the top picture, but I know that the door panels have been off at least once about 15 years ago.
Pioneer4x4 is offline
post #6 of 6 (permalink) Old Feb 18th, 20, 5:39 PM
Original 64-67 door handle installation was level to the ground (horizontal). Note that at least one of the repro Mfr's handles are made wrong (have the teeth oriented wrong) and cannot be installed correctly.
The window crank orientation (when rolled all the way up) varied by assembly plant -
  • KC - rear crank level pointing to the back of the car, front crank level pointing to the front of the car.
  • Balt - rear crank level (or one tooth up from level) pointing to the back of the car, front crank one tooth down from level pointing to the front of the car.
  • Fremont - rear crank one or two teeth up from level pointing to the back of the car, front crank one or two teeth up from level pointing to the front of the car.
  • ATL - all 4 cranks pointing halfway between down and toward the front of the car (this is the best looking of all of them, in my opinion)
  • Framingham - ??
davewho1 likes this.
Jeff Helms
-65 Z16 Survivor (Red/black/white int.) (
-65 SS Convertible (Red)
-66 SS L34/M20 Survivor Coupe (Aztec Bronze) - 'Vintage Legend' Certified (
jeffschevelle is offline
