Advice - Chevelle Tech
 2Likes
  • 2 Post By Alan F
post #1 of 12 (permalink) Old Dec 2nd, 19, 10:02 PM Thread Starter
Advice
Good Day all. I’m looking for some suggestions/information on how to make a 67 chevelle trunk look good with carpet or other ideas. Just looking to clean it up.
Hookem6 is offline
post #2 of 12 (permalink) Old Dec 2nd, 19, 10:12 PM
I sprayed my trunk with 3M Body Schutz and put a factory trunk mat down after. I think it looks pretty clean.
Johnny Bravo is offline
post #3 of 12 (permalink) Old Dec 2nd, 19, 10:58 PM Thread Starter
3M is like a rubberized adhesive..??
Did you cover the sides as well..??
Hookem6 is offline
post #4 of 12 (permalink) Old Dec 3rd, 19, 12:00 AM
It is a rubberized coating, yes. It's what I used as an undercoat and I did inside my fenderwells also. I thought it would be worth a shot in the trunk and it turned out nice, in my mind anyways. And yes, I went up the sides with it too. I coated everything except the deck lid. You can buy it at any auto paint supplier, but you have to purchase the gun to spray it with as well. Unless you know someone with a gun.
post #5 of 12 (permalink) Old Dec 3rd, 19, 4:24 AM
Re: Advice
I painted mine with bedliner paint then used cheap auto carpet from ebay.
ZZ69chevelle is offline
post #6 of 12 (permalink) Old Dec 3rd, 19, 9:25 AM
blm
Re: Advice
Carpet and especially a trunk mat will hold a good bit of moisture. Personally I wouldn't want either. Better solution is some kind of paint to spruce it up.
blm is offline
post #7 of 12 (permalink) Old Dec 3rd, 19, 3:47 PM
Re: Advice
My car always sits in the garage with the hood and trunk open, so moisture isn't really an issue. It can definitely be problem if you can't do that though. The cheap carpet from ebay is kinda thin and breathable too.
post #8 of 12 (permalink) Old Dec 8th, 19, 12:34 AM
David
Re: Advice
You can also get a gray or black gauzy-like trunk liner material from any auto upholstery supply house that is very stretchy and easy to work with. You use spray adhesive on one surface (if you want easy removal later) and it stretches easily over compound curves to make a nice finished look. I had a friend with a sewing machine make me a spare tire cover from it as well on an old Cadillac I used to own; when I sold it years later the buyer said he knew it was a well cared for car by the immaculate trunk The stuff is cheap, too.
72 El Camino
davidaugust is offline
post #9 of 12 (permalink) Old Dec 8th, 19, 8:41 AM
rick
Re: Advice
Black rustoleum and spatter paint, mines just black rustoleum for now
shovelrick is offline
post #10 of 12 (permalink) Old Dec 8th, 19, 9:20 AM
Allen
Re: Advice
Not an inexpensive option but you could do something like this after you take care of rust & paint:
https://www.alienenclosures.com/prod...-trunk-panels/
I don't know what your build goals are so may/may not fit in the plan. Personally, I think this treatment looks good on a modern street machine/protour type build but is a out of place/ a bit odd on a traditional hot rod. Maybe a simpler design would fit a traditional hot rod better...
Blown1932 is offline
post #11 of 12 (permalink) Old Dec 8th, 19, 1:38 PM
Re: Advice
Nothing looks better to me than being clean with the correct spatter paint and a fresh mat. I don’t like putting an enclosure in the trunk because it looks so small. Trunks get wet and I wouldn’t want carpet in the trunk for that reason.
Other opinions will vary!
von and RAIDER SS like this.
Originally Posted by Jordan Peterson
The motivation that drives the commission of the worst human atrocities is an inevitable social consequence of the refusal of the self conscience individual to make the sacrifices appropriate to establishing a harmonious life and their consequent degeneration into a kind of murderous and resentment filled rage propagating endlessly through its variations in society until everything comes to an end.
Alan F is offline
post #12 of 12 (permalink) Old Dec 8th, 19, 9:47 PM Thread Starter
Thanks all
Hookem6 is offline
