1967 300 model door panels - Chevelle Tech
 3Likes
  • 2 Post By Pete 67
  • 1 Post By BlueBalls71
post #1 of 9 (permalink) Old Nov 3rd, 19, 10:09 AM Thread Starter
Lou
I have a tear in my driver side door panel of my 1967 300 model two door post sedan. I can’t seem to find the correct panels for the 300 model. It’s not the deluxe and it’s not a Malibu. I don’t want to change to the Incorrect panel. Any suggestions? I attached photos.
ID:	606954   Click image for larger version
BlueBalls71 is offline
post #2 of 9 (permalink) Old Nov 3rd, 19, 1:22 PM
Re: 1967 300 model door panels
You're in luck. I have a set in that exact color. I took them off my '67 300 that I customized into a pro-touring car. I've been holding on to these waiting for someone who needed an original set.
PM me with your email or cell number & I'll send you some pics tonight when I get home from work.
augy and 68-13427 like this.
64 2 door Wagon Build thread
67 2 door Sedan LS1 T56
Pete 67 is offline
post #3 of 9 (permalink) Old Nov 5th, 19, 8:22 AM
If you get the ones Pete has offered, do not throw the other ones out. PM me.
When I works, I works hard.
When I sits, I sits loose.
augy is offline
post #4 of 9 (permalink) Old Nov 5th, 19, 10:15 AM
Is anything missing from the tear? If it is just torn open, like a flap, you may be able to repair it pretty good. Remove it, and remove the torn back board part from that area and smooth the vinyl back into shape and join it from the back, then replace some of the back board to support it.
Pioneer4x4 is offline
post #5 of 9 (permalink) Old Dec 11th, 19, 10:22 PM Thread Starter
Lou
It all worked out perfectly. Thanks Peter. Stored away for six years and now they look fantastic and a perfect color match.
Pete 67 likes this.
post #6 of 9 (permalink) Old Dec 12th, 19, 8:42 AM
Beautiful!
Do you still have the original ones that are damaged?
augy is offline
post #7 of 9 (permalink) Old Dec 12th, 19, 3:01 PM
Awesome! It's so great these door panels found a home after sitting in storage for so long.
Just curious, why did you decide to use the Malibu armrests instead of the original 300 armrests you removed?
Pete 67 is offline
post #8 of 9 (permalink) Old Dec 12th, 19, 3:52 PM Thread Starter
Lou
The old ones completely fell apart. I couldn’t find any the same size and these fit and matched color. If I come across originals that aren’t cracked, I’ll replace them. Much easier than the door panels would have been.
post #9 of 9 (permalink) Old Dec 12th, 19, 4:04 PM
I had those too, but sold them a few years back. I'll keep my eye out for you if I come across any.
Pete 67 is offline
