66 Dash installation order - Chevelle Tech
post #1 of 5 (permalink) Old Sep 5th, 19, 8:23 PM Thread Starter
Greetings!
I didn't take enough pictures of our dash when we took it apart a few years ago, and can't find the answer in my AIM.
Old posts promise photos, but the links have expired.
Does the clutch pedal bracket go over or under the dash when it is installed on the rods coming from the cowl?
Greg
GregSnook is offline
post #2 of 5 (permalink) Old Sep 5th, 19, 8:49 PM
Keith
Re: 66 Dash installation order
the clutch, brake pedal assemble should be the first thing installed then the heater box and then the firewall insulation pad
Maryland Chevelle Club #682
keithb is online now
post #3 of 5 (permalink) Old Sep 5th, 19, 11:45 PM Thread Starter
My apologies, poorly phrased my question, but thank you for the reply.
I have the column in, needed that to move the car off the trailer from the body shop, and around. The brake and clutch pedal assembly is on top of that. The dash also mounts using those two rods. Does the dash go above both the shaft and pedal assembly (I don't think so given the shape), or between the pedals and the shaft?
Thanks again,
Greg
ID:	602508   Click image for larger version
post #4 of 5 (permalink) Old Sep 6th, 19, 12:43 AM
I would think it would only fit correctly one way.
Drop the column
Attach dash
Reattach column
Unless I am totally forgetting something I never had to deal with the
clutch and brake assembly.
LKN BCK is offline
post #5 of 5 (permalink) Old Sep 6th, 19, 7:03 AM Thread Starter
Thanks, that's a big help!
Greg
