Vintage Air in a Non-A/C 70 - Page 2 - Chevelle Tech
post #16 of 24 (permalink) Old Sep 11th, 19, 11:04 AM
Claude
Re: Vintage Air in a Non-A/C 70
Originally Posted by Widetires22 View Post
I have a non A/C 70 with small block engine and the alternator on the right hand side. I am planning to order the Vintage Air COMPLETE kit for non A/C cars.
My question is, is there anything I need to be aware of when ordering or installing??
Also do any of you have pictures of your institutions under the hood and inside the car?
Also does the normal heater controls get modified in any way? Or does it have its own controls?
Thanks in advance
I had a Vintage Air system installed in my non-a/c '71 Chevelle. I'll answer your questions in order:
1° The only thing you need to tell them are that your car was a non-a/c car originally and also what kind of engine you have ...
2° I do have some pictures but it would be easier for me if I could e-mail them to you…
3° The kit comes with it's own controls but they look very similar to the original controls, so don't worry, it won't look "out-of-place" once installed.
Claude.
1971 Chevelle SS
toofastforyou is offline
post #17 of 24 (permalink) Old Sep 11th, 19, 12:38 PM
Once you use the Aeroquip EZ Clip system you'll likely never go back to standard crimping. Ideally it does require a special plier tool but it is relatively cheap.
traveler is offline
post #18 of 24 (permalink) Old Sep 11th, 19, 1:21 PM
I would imagine that if you used any other end than the one supplied you would have a hard time with any warrant issue. The crimp on ends supplied are easy peasy. Why buy a high dollar tool for one use?
SSJohn is offline
post #19 of 24 (permalink) Old Sep 11th, 19, 1:35 PM
Can you post a picture of the whole dash with the passenger door open?
Don
I’ll get that pic tonight for you. No need to wait on email that may never come.
SSJohn is offline
post #20 of 24 (permalink) Old Sep 11th, 19, 6:06 PM
Here’s a couple of shots, one from the pass side with the door open and one of the controls.
ID:	603080   Click image for larger version
SSJohn is offline
post #21 of 24 (permalink) Old Sep 14th, 19, 8:29 PM Thread Starter
Don
Originally Posted by SSJohn View Post
Pic # 4 is shot from the pass side showing the evaporator/heater box under the dash.
Pic #5 is the same, shot down low by the shifter towards the pass side.
Any auto a/c shop can crimp the ends for you. When I did mine they charged 75.00 to crimp the ends, evac and fill.
Gotcha thanks for everything
Don
//_____________:____________\\
/_____________________________\
|[__]_________|DF 22|____SS__[__]|
\_____________________________/
| : : : : : : : | -- \___/ - -| : : : : : : : :|
\________/ .. . . . . . . . .\________/
Widetires22 is offline
post #22 of 24 (permalink) Old Sep 14th, 19, 8:58 PM Thread Starter
Don
I see vents above the controls. Did your car come with A/C originally?
Don
post #23 of 24 (permalink) Old Sep 15th, 19, 8:55 AM
Yes, my car originally had a/c. The vents above the controls are not the originals, I couldn’t bring myself to cut off the back to attach the vintage air adapter. I did the cutting on a repop I bought. I still have the original which has a shut off lever between the vents.
SSJohn is offline
post #24 of 24 (permalink) Old Sep 16th, 19, 9:41 AM
Stan
Best thing since buttered toast...and if you look hard you can find the clips and pliars from Eaton, at a considerable savings.
Stan's Customs is offline
