'66 gas pedal / accelerator pedal will not stay on ball studs, any ide - Chevelle Tech
  • 1 Post By Chevy67
post #1 of 5 (permalink) Old Sep 1st, 19, 11:18 PM Thread Starter
wayne
On my '66 I have tried 2 different pedals, I have tried using my original ball studs and now a brand new pair of studs. I can get it on but it keeps popping out after a short time. Any ideas on what I should do? I also went under the carpet and cut the padding away thinking that maybe I was not getting the pedal all the way down on the studs, any help would be appreciated.
wsmith is offline
post #2 of 5 (permalink) Old Sep 3rd, 19, 1:21 AM
steve
Re: '66 gas pedal / accelerator pedal will not stay on ball studs, any
Is it possible to drill the pedal holes deeper without going through?
64tempestwagon is offline
post #3 of 5 (permalink) Old Sep 4th, 19, 3:45 PM
Kevin
I had that issue when I first acquired my Chevelle. I found out that despite thinking the pedal was down, I had to tap it with a rubber mallet and a block of wood to secure it over the ball studs. Sounds simple but might be something to look into.
davewho1 likes this.
"If you're not living on the edge, you're taking up too much space" - Jim Whittaker
AFR Eliminator 195's
Inglese 50mm 8 stack injection
FAST XFI Street
SC&C Stage II Plus suspension
Hotchkis/Hellwig sway bars
Tremec TKO 600
Chevy67 is offline
post #4 of 5 (permalink) Old Sep 4th, 19, 4:29 PM
^This.
David
davewho1 is offline
post #5 of 5 (permalink) Old Sep 6th, 19, 3:05 AM
Won't help... The studs have a 'ball' at the end, and the pedals have a "socket" that should snap into those balls...
Originally Posted by Chevy67
...I had to tap it with a rubber mallet and a block of wood to secure it over the ball studs...
I also like the idea of using a mallet to try and seat the sockets onto the studs...
I wonder if a little judiciously applied heat and maybe a squeeze with some pliars might tighten up the "sockets" on the back of the pedal...
TC #1366
Sold
Sold
1966_L78 is offline
