1967 Chevelle Interior rear window trim/molding - Chevelle Tech
 2Likes
  • 1 Post By Pete 67
  • 1 Post By augy
post #1 of 4 (permalink) Old Aug 26th, 19, 12:00 PM Thread Starter
Rocky
GM TC. So I had the car out in the sun this past weekend and noticed the rear window interior molding had come off partly, warped, and re-hardened out of shape. It looks like whomever last installed it used some kind of adhesive (looks like maple syrup) and is a mess. From what I was told that trim piece should have been a snap on part. What would be the best method of cleaning up the old adhesive? Some of it is obviously on the edge of the headliner that I will probably not be able to do anything about.
Thanks,
Rock
faded67 is offline
post #2 of 4 (permalink) Old Aug 26th, 19, 1:25 PM
re: 1967 Chevelle Interior rear window trim/molding
For the glue on the molding itself, use 3M adhesive remover. The color of the headliner would determine what I would use on it. Either way I would experiment in a tiny unseen spot before going to town. You don't want to use something that might permanently discolor it.
faded67 likes this.
64 2 door Wagon Build thread
67 2 door Sedan LS1 T56
Pete 67 is offline
post #3 of 4 (permalink) Old Aug 27th, 19, 8:29 AM
I use mineral spirits to remove adhesive from vinyl fabric. As Pete said, start with a hidden area to make sure the color isn't also removed, although I've never had a problem with that. Be gentle, and it might take more than one application.
faded67 likes this.
When I works, I works hard.
When I sits, I sits loose.
augy is offline
post #4 of 4 (permalink) Old Aug 28th, 19, 2:34 PM Thread Starter
Rocky
Re: 1967 Chevelle Interior rear window trim/molding
Appreciate the advice Pete/Steve!
faded67 is offline
