Window Crank Handle splines too deep - Chevelle Tech
 3Likes
  • 1 Post By HKalin
  • 1 Post By 2guitars
  • 1 Post By Johnny Bravo
post #1 of 9 (permalink) Old Aug 14th, 19, 5:23 PM Thread Starter
Anyone know who sells repros that have the correct spline depth so they engage? The panel springs push the handle out past where the spline engages.
Thanks!
Team Member 4327
ACES Member 08130
2guitars is offline
post #2 of 9 (permalink) Old Aug 14th, 19, 5:41 PM
Hank
Re: Window Crank Handle splines too deep
I don't get what your saying but on my car it had new handles on it but they would pop off because the horseshoe clip wasn't reaching the groove in the shaft of the mechanism. What I did was I hit the handle on more with a hard plastic tipped hammer. I would pull it back off and reposition it and hit it on again. Doing this made the splines fit together better and the handle was able to go on enough that the horseshoe clip was able to snap into the groove.
B52bombardier1 likes this.
HKalin is offline
post #3 of 9 (permalink) Old Aug 15th, 19, 9:00 AM
This ^^^^
Make sure you have the handle oriented exactly where you want it, then give it a good whack right on the splined shaft. I use a rubber mallet. It should pop right into place.
When I works, I works hard.
When I sits, I sits loose.
augy is offline
post #4 of 9 (permalink) Old Aug 15th, 19, 12:07 PM Thread Starter
It's none of that...the splines are set too deep in the hole and don't engage when the spring biases the handle outward. The clip holds it on fine. The splines need to be placed closer to the outside of the hole. If i push it in against the spring it engages the spline.
Make sense now? This is a problem with some repops and is mentioned elsewhere on the internet.
Team Member 4327
ACES Member 08130
2guitars is offline
post #5 of 9 (permalink) Old Aug 15th, 19, 4:10 PM
Hank
On another car I had the handles just felt sloppy on the shafts. I bought some replacements at Napa that were probably from the "Help" line of aftermarket parts. Those fit much better than what was on the car.
HKalin is offline
post #6 of 9 (permalink) Old Aug 16th, 19, 9:04 AM
Good to know. Never heard of that problem before. Thanks for posting.....
augy is offline
post #7 of 9 (permalink) Old Aug 16th, 19, 9:59 AM
Don
The repro handles I put on my "66" had the same issue,I got lucky and found a good set of original handles,door and window and they work as designed.
Like the song say's,"AIN"T NOTHIN LIKE THE REAL THING BABY"
Don B is offline
post #8 of 9 (permalink) Old Aug 19th, 19, 2:11 PM Thread Starter
Yea,
Will be at Corvettes at Carlisle this weekend and will look for some good used originals.
Tarheel Chevelle likes this.
Team Member 4327
ACES Member 08130
2guitars is offline
post #9 of 9 (permalink) Old Aug 21st, 19, 10:30 PM
Ground up has window cranks that the description says they have the proper spline depth and clip engagement. Hope that helps.
Johnny Bravo is offline
