floppy inside door handles? - Chevelle Tech
post #1 of 7 (permalink) Old May 24th, 19, 1:36 PM Thread Starter
I guess their is a spring somewhere. Anyone know?
Thanks!
1970 Chevelle, 400, UD Harold solid, 5.565 rod, standard bore, vortec heads, Jerico DR4, best ET 11.85, 113 MPH
1961 Buick Lesabre convertible, bone stock cruiser
ChevJerico is offline
post #2 of 7 (permalink) Old May 24th, 19, 2:27 PM
Re: floppy inside door handles?
Should be a spring and a small plastic disc slightly larger then the diameter of the spring...
69' SS396 Chevelle L78 396/375hp M-21 Close Ratio Cortez Silver
10 year Resto
It's brand new again!
02' Harley FatBoy, Diamond Ice Pearl and lots of chrome!
ACES# 3466
fastss396man is offline
post #3 of 7 (permalink) Old May 24th, 19, 2:59 PM Thread Starter
I think that's for the window crank. My handle doesn't return to the home position. Has no spring, just hangs.
post #4 of 7 (permalink) Old Aug 12th, 19, 12:33 PM Thread Starter
Anyone?
post #5 of 7 (permalink) Old Aug 12th, 19, 12:42 PM
I wish GM would of just ran a chrome screw through the center of the handle into the axle. Those handles are always loose and make racket. I'm one of those guys who likes everything to work smoothly without rattles, which is why I bought a 69 el Camino with its massive frame and heavy sedan door frames. I never understood this fear of letting the screws be seen. Frank Lloyd Wright said it best, "just let it show, let it be what it is"..
hydro462 is online now
post #6 of 7 (permalink) Old Aug 12th, 19, 1:37 PM
Half inch piece of foam/rubber goes between the door and the door panel on the earlier
cars. Could have a worn handle mechanism if there is that much slop?
Adding a bit oversize square or two of foam between door and door panel could help if you put a thick enough piece in there.
LKN BCK is offline
post #7 of 7 (permalink) Old Aug 12th, 19, 2:59 PM
Hank
I think the handle mechanism may have a return spring incorporated in it to return the handle to home. If you look at the picture you can see the end of the spring.
https://www.ss396.com/chevelle/IDH-9...elle&year=1970
HKalin is offline
How can you preserve a 66 SS hood from rusting on the inside? Jim_66SS Body Shop 7 Mar 5th, 19 8:57 PM
Epoxy, Sound deadening, and painting inside panels? alwaysavocado Body Shop 11 Feb 20th, 18 4:00 PM
Heater core replacement - 69 with A/C Slipstick Heating & Cooling 3 Dec 16th, 14 11:31 AM
69 door wont open from inside koolkeith19 Interiors 2 Jun 17th, 14 9:05 PM
need help on 69 e-brake cable connecting to inside ebrake pedel skibum Brakes, Suspension & Steering 3 Mar 10th, 13 11:39 AM
