68-69 3 spoke wheel horn button assembly - Chevelle Tech
  • 1 Post By LevonH
post #1 of 7 (permalink) Old May 18th, 19, 6:53 PM Thread Starter
Dennis
Does anyone have an exploded view pic of how the horn button parts go together for 3 spoke wheel in a 68-69? I'm putting on my 66 and the only pic I gave is for the stock 66 wheel. I believe I gave a mismatch of horn button/contacts/springs, etc but I can't tell for sure.
I'm hoping an exploded view will put this straight in my head.
Thanks,
Dennis
67_LS1 is offline
post #2 of 7 (permalink) Old May 26th, 19, 2:46 AM
Re: 68-69 3 spoke wheel horn button assembly
Great. . . . . .
KevinScott is offline
post #3 of 7 (permalink) Old May 26th, 19, 10:19 AM
sorry dont have a pic. but the install kit is different between tilt and non tilt. in case something seems odd. jom
Jim Mac is offline
post #4 of 7 (permalink) Old May 26th, 19, 12:03 PM
Levon
A quick search revealed a pile of Threads on this subject
I used "3 spoke steering wheel horn install"
https://www.chevelles.com/forums/16-...l-install.html
Many more with good info.
NickeyChevelle likes this.
Levon Hovagimian
Team Chevelle #279
1966 427 Corvette SOLD
Priddis Greens, Ab. Canada
LevonH is offline
post #5 of 7 (permalink) Old May 26th, 19, 4:50 PM
Bruce
Thanks,
Dennis
The '69 wheel is a diffefent depth than the '64 through '68 because Chevy redesigned the column for '69. The '69/'70 wheel is shallower that the '67/'68. It will fit and will give you more gut room.
As I recall, InlineTube has a small diagram of the assembly in their online Chevy Cataloge.
Our You Tube Vids:
NickeyChevelle is offline
post #6 of 7 (permalink) Old May 26th, 19, 6:27 PM
First mount the hub to the steering wheel with 6 phillips headed stainless steel screws. Be sure to mount the hub to the steering wheel with the hole in the hub at the 10 o'clock position. Then mount the horn contact, which is also the retainer for the center horn cap. The horn contact uses 3 phillips screws. These are not stainless steel. The horn contact has a tab hanging off the back side, which must also be mounted with the tab also at the 10 O'clock position. Then install the horn cap by snapping it into the horn contact.
RealRed70 is offline
post #7 of 7 (permalink) Old May 26th, 19, 8:04 PM Thread Starter
Dennis
Thanks, this is what I needed. I still had a mismatch of parts but with a little grinding of the plunger it now works.
Thanks everyone.
67_LS1 is offline
Horn button wiring Dannnnnn Electrical & Wiring 7 Dec 27th, 18 5:29 PM
64-66 wood wheel, hub and 65 horn cap keithb What's it worth? 2 Jun 17th, 16 1:28 PM
OPGI 3 spoke steering wheel install Lucus15 Brakes, Suspension & Steering 7 Nov 13th, 15 6:03 PM
What is the name for one of the horn button parts? DZAUTO Chevelle Tech 3 Apr 30th, 13 11:46 PM
66 Malibu horn button not making contact 66Malibu 1999 -- 1 Sep 8th, 99 3:24 AM
