1970 SS Dash Install - Chevelle Tech
 3Likes
post #1 of 23 (permalink) Old Apr 12th, 19, 8:56 PM Thread Starter
I am getting ready to reinstall my dash and not looking forward to it. It's the original so I know it's brittle and I really don't want to crack it. I have 2 questions. I've seen the dash installation guide on the SS396.com site.
1. If I bolt the dash back into the firewall, will I be able to reach behind it (no dash pad or windshield) to reconnect everything?
2. I read somewhere that someone screwed threaded rod into the upper 2 outboard dash mounting holes. Then they slid the dash over the threaded rod but not all the way against the firewall. I guess this allowed a little room to work behind the dash. The center of the dash would need to be supported but I would still be scared I would damage it. Is this a good idea?
I welcome any other ideas or advice. BTW it is a non AC car if that matters and the interior is gutted right now.
Thx in advance.
1970 SS396 Chevelle
468 ci, TH 400, 3:73 posi
SS468 is offline
post #2 of 23 (permalink) Old Apr 12th, 19, 9:06 PM
Re: 1970 SS Dash Install
Hello,
It helped me to have the seats out when man-handling the old sweep style and new SS dash on my 70 El Camino. Use two people if you are worried but after I did the installation the first time, it was easy for me alone after that. My dashboards have been in and out at least half a dozen times.
A fellow by the name of "Chris Craft" on You Tube has an excellent video about removal and installation of Chevelle SS dashboards. Your anxiety will be greatly relieved after watching his dash video.
Yes, you can reach things from the top and bottom of your dashboard - very easy with the seats out. Also very easy with your windshield out. My glass was also out but is installed now and this made it only somewhat harder but not hard.
B52bombardier1 is offline
post #3 of 23 (permalink) Old Apr 12th, 19, 10:44 PM
I used the all thread rod in the outer holes as you have described, and had plenty of room to hang it and work. Once everything was installed, I just pushed it all back and fastened the rest of the bolts.
"SSuper Dave" Palmer
A.C.E.S. #1483 TC #32 Gold
SSuper Dave is offline
post #4 of 23 (permalink) Old Apr 13th, 19, 11:08 AM
Terry
Connect all of your dash harness to the gauges , headlight switch, wiper switch and install as a sub-assembly. I just did this in my '68 and it made it easier than laying on my back to install wires after dash is in. I don"t have any experience with the '70 model , so this might not work for you. Terry
68-13427 is offline
post #5 of 23 (permalink) Old Apr 13th, 19, 11:26 AM
Thx in advance.
Make a support that goes from one of the braces on the dash down to the floor. There is a brace near the ash tray you can attach your support to that brace. To paraphrase Jack Nicholson's rant in "A few good men" : "You WANT that brace there you NEED that brace there because........". The weakest point in the dash is the area down there near the ash tray. If / when you put those screws into the dash attachment points to support the plastic dash the plastic dash itself kinda wants to bend around the area of the ashtray. I used the support idea when I was doing what you are planning. Not 100% sure it was necessary but a piece of angle iron from The Depot was cheap insurance IMHO.
SSJohn likes this.
oman is offline
post #6 of 23 (permalink) Old Apr 13th, 19, 4:24 PM
Any pics of that brace?
72soft-top is online now
post #7 of 23 (permalink) Old Apr 13th, 19, 5:32 PM
Nope no PICs. Don't over think this. A simple straight piece of angle iron running from the floor up to the metal brace that is located on, and permanently attached ,to theback of the dash. Might have to drill a hole in the factory brace. The one I made came down to the floor just to the right(passengers side) of the tunnel. Think of it as a "crutch" that supports the dash and gives it mid span support so it doesn't hang suspended only at the farthest left and right sides of the dash.
oman is offline
post #8 of 23 (permalink) Old Apr 14th, 19, 1:32 PM Thread Starter
Thx for the help and thx Rick for the ChrisCraft video suggestion. I was getting ready to get ahead of myself. I don't have the pedals back in or the firewall insulation. I guess I'll be ordering that today. Any suggestions? I like the idea of using something precut that may fit better.
Thx.
1970 SS396 Chevelle
SS468 is offline
post #9 of 23 (permalink) Old Apr 14th, 19, 2:52 PM
I just use a couple of old couch cushions over the transmission hump to support the center of the dash.
70SSTHUMPER and OO52 like this.
RealRed70 is offline
post #10 of 23 (permalink) Old Apr 15th, 19, 9:29 AM
David
Definitively use the threaded rod to hang the dash from, SO much easier. I used a scissors jack sitting on the trans hump with a rag to cushion between the dash and the jack. Was real easy to adjust to the exact amount of height (support) needed for the middle of the dash.
davidaugust is offline
post #11 of 23 (permalink) Old Apr 15th, 19, 11:26 AM Thread Starter
Thx David.
Has anybody used the Flatline Barrier brand sound/heat barrier?
1970 SS396 Chevelle
SS468 is offline
post #12 of 23 (permalink) Old Apr 17th, 19, 3:35 PM
Deon
When I did the dash in my 72 I used a bungie cord on the bracket by the AC up to the hole for the rear view mirror. Held the center fine and allowed me to move it around to connect items. I used 5 or 6" inch carriage bolts from Lowes on the outers to allow it to slide back and fourth as needed.
72 Chevelle, 454, TH400, 3:73's
72SS454Chevelle is offline
post #13 of 23 (permalink) Old Apr 18th, 19, 5:38 PM
David
I used Second Skin, a thin peel and stick sound dampener, to the entire cowl area and the sidewalls. On top of that I applied a foil faced felt, about 1/2" thick that is stocked by a local automotive store. In the photo I'm using scraps of paper to make a template so I can cut a single piece of the felt with the properly spaced cut-outs or slits. I had purchased a barrier kit from OPGI for the cowl and firewall which was much flimsier and returned them. Fortunately my existing (probably original) firewall insulation was complete and in good shape as it is twice as heavy as the OPGI piece was.
I would re-emphasize that using threaded rod is much better than using carriage bolts because the rod is already in place as you and a friend walk the dash back into the car and hang the dash instead of holding the dash, picking up a carriage bolt in one hand and lining it up with the dash carrier holes and then with the cowl brackets and get the bolt threaded into the cowl.
The green steering column is because I'm changing out my interior from black and saddle to green and ivory. Since the dash was already coming out for other reasons I used the opportunity to start the color change.
post #14 of 23 (permalink) Old Apr 20th, 19, 10:23 AM
Thx David.
I just finished installing Fatmat yesterday. Was pretty easy to work with. I purchased 75 sq ft on eBay of 80mil thickness for $150.
post #15 of 23 (permalink) Old Apr 20th, 19, 10:33 AM Thread Starter
Thx for the help. From what I've read, nobody makes an underdash insulation pad that fits good. I don't know why that was even installed from the factory when you have the firewall insulated from the engine bay but I guess every little bit helps.
Can someone recommend a vendor that they used for the underdash and firewall jute style insulation? Should the retaining "plugs" be plastic or rubber?
I also plan on using a foil backed sound dampener. Does this go on the sheet metal then the jute on top of that?
Thx.
1970 SS396 Chevelle
SS468 is offline
1970 SS Dash Plg r70454ss Electrical & Wiring 5 Jul 22nd, 16 9:15 PM
My 1972 dash removal with pics Dru683 Interiors 7 Feb 6th, 16 11:37 PM
'70 ss dash conversion / A/C install Montana '70 Interiors 13 Sep 28th, 15 2:39 AM
Ready to install SS dash in my 71 - See any issues? wiredawg Interiors 13 Oct 21st, 13 10:00 PM
1970 Vintage A/C vs. new dash whamilton1 Heating & Cooling 3 Oct 7th, 13 6:37 PM
