Astro Air install - Page 2 - Chevelle Tech
 7Likes
post #16 of 18 (permalink) Old Apr 4th, 19, 9:52 AM Thread Starter
Paul
Re: Astro Air install
Originally Posted by BobinPA View Post
I am in the process of converting my classic air under dash vents in my 68 to the factory style vents. The after market under dash vents are really low, not fully adjustable, and as a result do not circulate air all that well, unless you like all the air going into your crotch. As to size the GM vents use a 2 1/2" hose and the aftermarket kits use 2". You can buy a vintage air adapter on Jegs and Summit for a few bucks and they work great. It all clicks together. I already have the passenger side vent installed, and it moves a lot more air and is better placed for passenger comfort. Shorter hose, less restriction, and better placement are all plusses in my book. I just got the parts for the center dash vent, so will be updating the driver side and center vents in the coming weeks.
What kinds of problems was the other member bringing up?
Cool if you have a chance/don't mind could you shoot me the Part numbers for what you are using for your vents and such. He was vague in his wording he just made it seem like it would be more trouble than its worth and or would just not work, but maybe I was just misunderstanding him or he was misunderstanding what I wanted to do.
barkerpa3466 is offline
post #17 of 18 (permalink) Old Apr 4th, 19, 2:02 PM
Originally Posted by barkerpa3466 View Post
First and most importantly I like the look of the 69 dash over the 68 and as an afterthought security is a bit better with a locking steering wheel, not foolproof by any means but I figure that anything that slows down a thief makes it more likely they will get caught. also going to do some type of kill switch.
I wonder if the security aspect is true. I think car thieves got pretty fast at popping off the column mounted lock with a slide hammer. Having to actually hot wire a car might be a lost art.
68 SS396
Team Chevelle Gold #14
Gene McGill is offline
post #18 of 18 (permalink) Old Apr 4th, 19, 6:08 PM Thread Starter
Paul
Yeah I think your right but I am also going to do a kill switch or fuse to help with that end. I think the bigger deterrent will be the fact that it is a manual. not a lot of people can drive stick any more.
This Thread is more than 463 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
69 Malibu Air Lift air bags for daily use 658Chevy Brakes, Suspension & Steering 15 Apr 8th, 19 10:09 PM
Open Element Air Cleaner Shroud.. hydro462 Engine 23 Feb 20th, 19 8:34 PM
Under hood air flow at idle lucifershammer Heating & Cooling 10 Jul 12th, 16 11:12 PM
Front Suspension bushings GatorsUF Brakes, Suspension & Steering 22 Mar 31st, 15 5:09 PM
Had it with electronic fans! 70 nialator Heating & Cooling 95 Jun 8th, 13 7:34 PM
