Heated seat switch - Chevelle Tech
post #1 of 24 (permalink) Old Feb 25th, 19, 8:08 PM Thread Starter
Alex
Heated seat switch
I’m looking at adding heated seats to my 69’s buckets when I sew the leather covers. I’m contemplating on how I want to do the switches. Looking at my rear defogger set up, it would seem to work as a 3 position switch in the on-off-on configuration.
So here’s my idea I’ve figured out a way to reproduce a impala style bezel that mounts two of those switches. In the original it housed the rear defogger and power top switches. I’m going to use an acid etch with a resist to basically reproduce that bezel in brass. Then chrome plate it and fill with black enamel. That switch bank will be mounted in the console plate. It will hopefully not look out of place to the casual observer.
My problem is no one is reproducing the rear defogger switch, and I need two. Is there anyway to make a power top switch non momentary? The switches themselves seem the same, just the power top switch is momentary in both positions while the rear defogger is not. This post would probably make more sense with pictures lol. Also does anyone know what font gm used on the 69 defogger bezel?
aem7272 is offline
post #2 of 24 (permalink) Old Feb 25th, 19, 8:36 PM
Re: Heated seat switch
Alex -
I think the problem you're going to run into is there's not detent in the power top switch, so even if you could remove the spring action, it's not going to stay in the on position.
I'm assuming you're trying to match the existing switch styling, but it might be easier to add an illuminated rocker switch that shows when the heated seats are turned on?
Just a thought...
jim
Jim's69Ragtop is offline
post #3 of 24 (permalink) Old Feb 25th, 19, 8:48 PM Thread Starter
Alex
Yea that is a good point it most certainly would be easier to just use two illuminated rockers. My other option is to just use a couple of rocker switches from digikey and adapt the paddle off of a power window switch. It will have a similar look but will necessitate a different attachment scheme for the bezel. I’m working on a bezel for a push button reverse lockout as well. It’s going to look pretty cool and might have some people scratching their heads at my “options”.
aem7272 is offline
post #4 of 24 (permalink) Old Feb 25th, 19, 11:37 PM
Terry
Alex, can you use a heated seat switches from a newer G.M. vehicle? Terry
68-13427 is offline
post #5 of 24 (permalink) Old Feb 26th, 19, 6:41 AM Thread Starter
Alex
Yes modern switches are no problem at all to find. My goal is to have the switches look like they came in the car 50 years ago. My goal is to have a two chrome paddle rocker switches in a chrome plated bezel mounted on the center console plate.
aem7272 is offline
post #6 of 24 (permalink) Old Feb 26th, 19, 7:05 AM Thread Starter
Alex
Here is the mock up for the bezel that will mount in the console plate. Its not to scale and in reverse. All the black areas would be chrome and the white areas will be enamel filled.
Name:	Heated seats bezel.jpg
aem7272 is offline
post #7 of 24 (permalink) Old Feb 26th, 19, 11:33 AM
Originally Posted by aem7272 View Post
Iím looking at adding heated seats to my 69ís buckets when I sew the leather covers. Iím contemplating on how I want to do the switches. Looking at my rear defogger set up, it would seem to work as a 3 position switch in the on-off-on configuration.
So hereís my idea Iíve figured out a way to reproduce a impala style bezel that mounts two of those switches. In the original it housed the rear defogger and power top switches. Iím going to use an acid etch with a resist to basically reproduce that bezel in brass. Then chrome plate it and fill with black enamel. That switch bank will be mounted in the console plate. It will hopefully not look out of place to the casual observer.
You could add latching relays to the momentary outputs of a momentary switch (like what is happening with a power top switch). By moving the switch to one position and then releasing it, the latching relay would close allowing power to flow to the seat heaters and then if that same switch was moved once again to that one position and released once again, the latching relay would open stopping the flow of power to the seat heaters.
Always working on something:
Jim Streib is offline
post #8 of 24 (permalink) Old Feb 26th, 19, 12:09 PM Thread Starter
Alex
That's a great idea Jim. I believe I was over thinking the problem. I was under the impression I needed switches that would be rated for higher amp draw. Once I dug deeper into the seat heater kit, the switches just trigger a brain box that controls the heating elements. I've picked up some switches that I think will work. Luckily they come with measured drawings so designing the resist for acid etching the bezel should go smoothly. I'm still debating where to locate the switches for the rear seats. They will likely be located near the power window switch.
aem7272 is offline
post #9 of 24 (permalink) Old Mar 1st, 19, 2:42 PM
Drew
Did this ever Happen?
Pics
1sikride is offline
post #10 of 24 (permalink) Old Mar 1st, 19, 5:27 PM
blm
Hey guys,
Find a way to convert standard seats to cooled seats and I'm on board.
I actually looked into converting my seats to cooled seats and although possible it's not probable. Several newer cars offer this feature but it would take an involved retrofit from a donor vehicle. Comments?
By the way if one could manage to install cooled seats they would also be capable of heating the seats as well because the cooled seats use sort of a,heat pump which is capable of heating or cooling.
blm is offline
post #11 of 24 (permalink) Old Mar 1st, 19, 6:44 PM Thread Starter
Alex
Pics
It's happening. The ferric chloride and toner transfer paper showed up today, the switches should show up tomorrow, and the brass bar stock should be here on Monday. I should have bezel design finalized tomorrow or Sunday. If it is successful I'd be happy to share the files and a parts list.
Originally Posted by blm View Post
Hey guys,
There is a kit out there, but it is a little more involved than just adding heating elements. I believe it runs on a peltier device and fans to provide heating and cooling. Cooling would be most effective with perforated leather or vinyl to facilitate airflow.
aem7272 is offline
post #12 of 24 (permalink) Old Mar 2nd, 19, 8:39 AM
blm
I believe perforated leather is almost a must. It has been a while since I looked at it but IIRC it has ducting to carry the heated and cooled air. So there must be an outlet for that air. I thought for the multitude of classic cars that don't have air conditioning it would be a good alternative and wouldn't be rob any horse power. Think it would be a challenging mod and I have never seen a classic car with that modification. Just heated seats is an easier, less complicated modification.
blm is offline
post #13 of 24 (permalink) Old Mar 2nd, 19, 9:36 AM
Shane
If that switch matches the defroster switch perfectly you could probably sell those.
If you put this kit together, you could sell it...
If you make a mistake, your element will burn your seat cover, your Jean's, and your backside.
fishhead is offline
post #14 of 24 (permalink) Old Mar 2nd, 19, 11:24 PM Thread Starter
Alex
I've finished the initial design the bezels. I'm pretty happy with how they turned out. I was taking apart my rear defogger switch to get some measurements today, and realized that the mushy feeling when engaging the switch was due to a broken pivot ear. It looks like I will be casting a new paddle switch as well for this project.
aem7272 is offline
post #15 of 24 (permalink) Old Mar 3rd, 19, 9:06 AM Thread Starter
Alex
I wasn't happy with the font. I think this one is closer.
Name:	heated seat bezel.jpg
ID:	587908   Click image for larger version
Name:	heated seat bezel flipped.jpg
aem7272 is offline
This Thread is more than 404 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
Helpful Headlight Switch Info Coppertop Electrical & Wiring 38 Nov 17th, 18 5:08 PM
rear seat top to package tray gap tx68chevelle Interiors 2 Nov 14th, 15 7:04 AM
TMI seat covers/buns for the 65 wagon Rich-L79 Interiors 4 Nov 2nd, 15 6:51 PM
Rear seat removal & rear quarter window repair - 1968 Malibu Proc Interiors 16 May 2nd, 14 8:07 PM
Need Help with my Ignition! rriley Electrical & Wiring 2 Oct 18th, 12 10:52 AM
