1968 Dash Ignition Switch Hole - Chevelle Tech
post #1 of 16 (permalink) Old Jan 22nd, 19, 3:12 PM Thread Starter
Hey Guys, first post ever. I need some help. I got a 1968 Chevelle 2 Door Post. I bought when it was 14 years old for 300 dollars and everything is not orginal. I've had an aftermarket igntion switch and a hand made dash for the past 10 years. I decided to get an semi orginal dash, and now have to figure out how to get my ignition switch to mount. I don't really understand the what was in the hole to start with. I know a bezel was there (though idk what it actually really looks like) , but what holds the switch up in the back. What holds my circle in a circle? Any help is apperciated.
ImYourHuckleberry is offline
post #2 of 16 (permalink) Old Jan 22nd, 19, 8:00 PM
Ben
Thereís a metal nut and the plastic chrome bezel. Ignition goes in from the back, metal nut (thatís round) goes on the snug the switch and hold it in place. Then plastic chrome bezel threads on to look good. Thereís also a piece of metal that goes behind the plastic dash between the ignition switch that also gets sandwiched between lighter and connects to the gauge cluster. I think itís for grounding.
davewho1 likes this.
No car yet; currently looking for 66-69 project/driver.
skreddy is offline
post #3 of 16 (permalink) Old Jan 23rd, 19, 10:29 AM
Re: 1968 Dash Ignition Switch Hole
[QUOTE=skreddy;11014816] Thereís also a piece of metal that goes behind the plastic dash between the ignition switch that also gets sandwiched between lighter and connects to the gauge cluster.
This is what the switch actually mounts to. The switch does not mount to the bezel. It mounts to this bracket that is mounted to the back of the bezel. It also holds the lighter, which is the reason the bracket needs to be grounded; without grounding the lighter wont work.
68 SS396
Team Chevelle Gold #14
Gene McGill is offline
post #4 of 16 (permalink) Old Jan 23rd, 19, 10:39 AM
I have one of those brackets for sale. Private Message me if interested.
RealRed70 is online now
post #5 of 16 (permalink) Old Jan 23rd, 19, 11:31 AM Thread Starter
Thanks alot. That helps!
post #6 of 16 (permalink) Old Jan 23rd, 19, 3:02 PM
Greg
Huckleberry,
Here are some more pix showing the ignition switch setup on the instrument carrier.
Greg
Name:	20161114_Dash carrier_0028.jpg
ID:	584196   Click image for larger version
Name:	20161116_Dash carrier_0001.jpg
ID:	584198   Click image for larger version
Name:	20161116_Dash carrier_0002.jpg
My 68
and my 68
. In 1968 I got my
66 Chevelle SS. 30 years later, I got my
. Both Chevelles are in the same location.
Greg P is offline
post #7 of 16 (permalink) Old Jan 23rd, 19, 9:32 PM
Terry
Huckleberry, Nice looking car, Welcome to the show. Terry
68-13427 is offline
post #8 of 16 (permalink) Old Jan 23rd, 19, 10:53 PM
I sent you a Private Message.
post #9 of 16 (permalink) Old Jan 24th, 19, 8:00 AM Thread Starter
Thanks Terry!
post #10 of 16 (permalink) Old Feb 9th, 19, 3:55 PM Thread Starter
Got my ignition in thanks guys.
post #11 of 16 (permalink) Old Feb 9th, 19, 4:25 PM
I sold you the bracket and switch. Did you have to drill out the lock part in order to separate it from the bracket?
post #12 of 16 (permalink) Old Feb 11th, 19, 8:34 AM Thread Starter
I put channel locks on the back of the switch trying to take the nut off. Broke the switch. However with a little wd-40 and Big Channel Locks. I got the nut off. The bracket was all i needed. Thanks for sending it so quick. My fixing things is trending up since I joined this board.
post #13 of 16 (permalink) Old Feb 12th, 19, 12:21 AM
Terry
Huckleberry, whose gauges are you running? Terry
68-13427 is offline
post #14 of 16 (permalink) Old Feb 12th, 19, 8:07 AM Thread Starter
Terry,
I went with these.
post #15 of 16 (permalink) Old Feb 12th, 19, 8:19 PM
Terry
linky no worky.
68-13427 is offline
