Dynamat worth the price? - Chevelle Tech
 17Likes
post #1 of 48 (permalink) Old Jul 21st, 18, 8:47 PM Thread Starter
Just noticed how pricey it is. Is it worth it? I see they have precut kits for Chevelles.
1970 Chevelle, 400, UD Harold solid, 5.565 rod, standard bore, vortec heads, Jerico DR4, best ET 11.85, 113 MPH
1961 Buick Lesabre convertible, bone stock cruiser
ChevJerico is offline
post #2 of 48 (permalink) Old Jul 21st, 18, 9:06 PM
Mark
Re: Dynamat worth the price?
i used Fat Mat in mine. I like it because it does keep the noise down.
shovelrick likes this.
ZZ502 Short block
Holley Avenger MPFI
612HP/594TQ
MarkP is offline
post #3 of 48 (permalink) Old Jul 21st, 18, 9:19 PM
blm
Lots of more reasonbly priced options. Most are just as good as Dynamat. Fatmat is one.
blm is online now
post #4 of 48 (permalink) Old Jul 21st, 18, 9:20 PM
I bought a roll of insulation from Home Depot. Rolled it out, cut to fit and glued it in. A little more labor than Dynamat but the price savings was well worth it.
ID:	570956   Click image for larger version
70 El Camino SS 396
68 GTO (Thanks Mom)
06 Silverado
07 SRX
OO52 is offline
post #5 of 48 (permalink) Old Jul 21st, 18, 9:23 PM Thread Starter
Good info thanks guys. A couple options. I'm doing for both noise and heat.
post #6 of 48 (permalink) Old Jul 21st, 18, 9:25 PM
I used RAAMmat BXT II with Ensolite IUO in mine. I would do it again in a heartbeat.
'69 Malibu
Not2Fast is offline
post #7 of 48 (permalink) Old Jul 22nd, 18, 12:26 AM
Vern
I replaced the siding on my house and used the tinfoil mating underneath the new siding . Had some left over so I installed it two layers think under the carpet on floor and firewall of my 52 Buick. Before after a hundred miles of 100 degree heat you could fry eggs inside the car on the carpet. After the tinfoil mating my wife swears the car is way cooler than before, you cannot feel the heat radiating off the firewall. I am sure this is the same quality as Home Depot.
suntreemcanic is offline
post #8 of 48 (permalink) Old Jul 22nd, 18, 2:21 AM
Mark
That's a mouthful!!! It does look like a decent system though.
ZZ502 Short block
Holley Avenger MPFI
612HP/594TQ
MarkP is offline
post #9 of 48 (permalink) Old Jul 22nd, 18, 3:04 AM
I used Lobucrod EZ Cool in mine, but apparently they sold out to someone else. It was about .55/sq. ft. at the time. Now it's around $1/sq. ft.
I did the floor (double layer), the hood, inside the cab, etc.
(Sorry, but the new format won't let me post pics direct)
http://i66.tinypic.com/2n8soyx.jpg
http://i66.tinypic.com/qmxa9y.jpg
I've seen others using peel and stick stuff from Lowe's and Home Depot, and they are quite satisfied.
The thing to consider is an adhesive backed material can only be cut one way. But one that requires adhesive as you install it can be cut in either direction, a mirror image.
Need 2 kick panels? Cut 'em at the same time, spray or brush the adhesive, you're done.
Pre-glued won't work that way. You have to figure out which side the adhesive is on before you cut, so you'll end up with way more waste of material when you're finished!
Good luck.
'66 El Camino, 327, 5 speed, 3.31 posi.
Custom painters don't screw up! They just add more graphics.
Moderator - nevadashooters.com
Tophog is offline
post #10 of 48 (permalink) Old Jul 22nd, 18, 9:23 AM Thread Starter
Good luck.
Didn't even think of all that. Thanks for the heads up. I'm going to look at Home Depot as well.
post #11 of 48 (permalink) Old Jul 22nd, 18, 9:30 AM Thread Starter
Anyone know what they call the peel and stick type that Home Depot sells? Trying to find it on their website.
post #12 of 48 (permalink) Old Jul 22nd, 18, 9:32 AM
I'm getting ready to do my 56 Chevy 210. I've Lizard Skinned the roof and floor already. A friend recommended I get "Cool It" from Summit. It's here and I intend to go from the firewall to the panel behind the rear seat with the stuff, inside the quarter panels and doors. Haven't decided about the roof yet, but not putting in a headliner for a while anyway. If this works as well as I expect, I'll be pulling the interior out of my Chevelle and doing the same thing.
66 Malibu
busterwivell is online now
post #13 of 48 (permalink) Old Jul 22nd, 18, 9:41 AM Thread Starter
Found this searching the net. Guys say it's very similar to Dynamat. Don't think it is sticky back.
https://www.lowes.com/pd/Reflectix-5...BoC1RkQAvD_BwE
post #14 of 48 (permalink) Old Jul 22nd, 18, 12:34 PM
Trying again. My previous reply was rejected because my “security token” was an issue. (?). Anyway, do SOMETHING. I used Dynamat in a Jeep and it made a huge difference in interior noise level.
any4xx is online now
post #15 of 48 (permalink) Old Jul 22nd, 18, 12:58 PM
rick
I found enough Dynamat Extreme at about 1/3 price to do the firewall to under the front seats on CL, then Fatmat ed the rest of the floor, behind rear seat & package tray, doors & under quarter glass, Reflextix (light weight) from Lowes for the roof with spray adhesive, personally I wouldn't pay retail for Dynamat when FatMat is just as good and cheaper
davewho1 likes this.
shovelrick is offline
This Thread is more than 625 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
