Console Top Plate Mount Repair - Chevelle Tech
  • 1 Post By paul bell
post #1 of 14 (permalink) Old Jul 1st, 18, 11:22 AM Thread Starter
blm
On a 68-72 console. About half of the plastic mounting holes on my console are stripped out. Has anyone come up with a way to repair or retap those mounting holes?
I assume one could fill the existing holes with epoxy or something else and then just drill a hole smaller than the mounting screws.
Another possible fix that I am considering is bonding a thin piece of aluminum to the underside of the mount that has a predrilled hole hole in it to accept the mounting screw.
Not even sure what are the correct screws. Mine are a mixture of fine threads and threads like a sheet metal screw. I assume the fine thread are the correct screws and as those mount holes failed those screws were replaced with the more aggressive threaded screws.
blm is offline
post #2 of 14 (permalink) Old Jul 1st, 18, 11:30 AM
Re: Console Top Plate Mount Repair
Drop into the hole a one inch length of 16 gauge wire with insulation. Then run in the screw.
71350SS likes this.
LS1tech.com supermoderator.
How may I help you?
1999 Trans Am-500hp
paul bell is online now
post #3 of 14 (permalink) Old Jul 1st, 18, 11:59 AM Thread Starter
blm
Does anyone know who offers the correct screws? An old thread said AMK had them #B11558 but those are out of stock.
blm is offline
post #4 of 14 (permalink) Old Jul 1st, 18, 12:00 PM
I have put a drop of epoxy into the hole as you run the screw in. I think they are supposed to be a coarse trim screw, like is used everywhere else on the console.
Whatever fix you do, I have found that eventually they will strip as its 50 yr old plastic.
Sent from my HTC6545LVW using Tapatalk
Scott W.
Electrical Engineer
700R4
This is how we roll:
red68chevL is offline
post #5 of 14 (permalink) Old Jul 1st, 18, 12:18 PM
Bart
https://www.jegs.com/i/RestoParts/759/97CH030/10002/-1
69SS Daytona yellow
L35, M-20, 3.73
"AC's 2 by 75...... you roll'em down & drive
"Time treats everybody like a fool"
surmin69 is offline
post #6 of 14 (permalink) Old Jul 1st, 18, 12:46 PM Thread Starter
blm
Thanks for the Jegs reference, but if that photo is the actual contents of the kit, which I assume it is then that kit does not contain the top plate screws.
blm is offline
post #7 of 14 (permalink) Old Jul 1st, 18, 12:59 PM
The information on that page says it covers the top plate. Those screws should be the small black ones in the picture (the ones on the bottom row) - they look just like the screws on my '71 console top plate.
If you view it on the actual company webpage, you can enlarge the picture to see the screws better:
https://www.restoparts.com/product.asp?item=97CH030
My Chevelle w/ open headers:
WakkoWarner is offline
post #8 of 14 (permalink) Old Jul 1st, 18, 1:22 PM Thread Starter
blm
I could be wrong but those screws look like pan head screws and they are showing 9 of them. The top plate screws are oval head and should be 6 of them?
If they are the screws then they are fine thread. Guess I could call them to confirm?
Bart: guess I am wrong as those are an OPG item. One review of that kit on the OPG site says they are exact copies of the screws for their 70 Chevelle console.
blm is offline
post #9 of 14 (permalink) Old Jul 1st, 18, 2:10 PM
Bart
I went the epoxy route when I fixed mine, I had no screws to compare, so I just went with that screw kit. Went back together and looks good
69SS Daytona yellow
L35, M-20, 3.73
surmin69 is offline
post #10 of 14 (permalink) Old Jul 1st, 18, 5:11 PM
Here are some original screws. They have a fine thread. The look different than the ones in the link to me. I use JB Kwik weld to fill the holes. Then I re drill them. Put the top plate in place as a template to do the drilling. Put masking tape on the bottom sides of the holes so that it does not just drip out the bottom.
https://www.chevelles.com/forums/olp/...tor/attach.gif
RealRed70 is offline
post #11 of 14 (permalink) Old Sep 1st, 19, 3:06 PM Thread Starter
blm
Ok, finally got around to repairing this. Well kind of repairing it.
First I acquired the correct screws in a screw kit #97CH030 from Summit Racing. Think it's an OPG item sold through Summit.
Wanted to try the least invasive first. So I tried wrapping the screw threads with Teflon tape. That didn't work. So I got some thin copper wire (about .0020 thick) and cut into pieces about 2 inches long. Just bent them into a U shape and hung one piece over each of the six plastic screw holes in the console. Worked great. This is pretty much what Paul suggested.
I'm sure the JB Weld would of worked but this was much easier. Pretty sure it will hold till it is taken apart then worst case will just have to replace the wires.
blm is offline
post #12 of 14 (permalink) Old Sep 1st, 19, 3:13 PM Thread Starter
blm
The wire
blm is offline
post #13 of 14 (permalink) Old Sep 1st, 19, 6:17 PM
Casey
Apply equal force in opposite directions! and Viola!
1968 Malibu sport coupe to go with
my Barbie wife of the same year!
Capt Casey is offline
post #14 of 14 (permalink) Old Sep 2nd, 19, 12:30 AM
Shane
I've rebuilt consoles, grilles, holes, steering wheels, etc. With JB Weld. It's amazing stuff and harder and stronger than the original plastic.
You can rebuilt the supports and trim,shape them with dremel.
Aluminum foil, the Reynolds type, is great for shaping, patterns, and moulding also.
Repaint.
fishhead is offline
