new door& window felt-WHO? - Chevelle Tech
 2Likes
  • 1 Post By augy
  • 1 Post By BillK
post #1 of 9 (permalink) Old Apr 11th, 18, 8:00 PM Thread Starter
Trying to get an idea which manufacturer is making the best door rubber & window felt? also I am thinking of maybe trying something new instead of standard headliner. Is there anyway to make a one pc roof liner w/ material? This is all for a 71 El Camino.
thanks
urleycay is offline
post #2 of 9 (permalink) Old Apr 11th, 18, 9:57 PM
Mr Bill
Re: new door& window felt-WHO?
u,
Its been a few years since I did the window felts on my 71 but I tried two different suppliers and they both sucked. Did not fit or look right. I ended up taking a few months finding NOS stuff and paid dearly for it but it fit and looks right.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Team Chevelle #100
BillK is online now
post #3 of 9 (permalink) Old Apr 12th, 18, 7:05 AM
repops.com for window felt kits. Not sure if they have door rubber.
jeffs68 likes this.
When I works, I works hard.
When I sits, I sits loose.
augy is offline
post #4 of 9 (permalink) Old Apr 12th, 18, 7:58 AM
Rich
I bought my door rubber / weatherstrippingfrom GroundUp and put it on two weeks ago. The doors open and close nicely now. Expect the new door rubber to make it VERY hard to close the doors for a few weeks at best (probably a month or two for it to really settle in). After install, let the car sit out in the sun if possible, to help the rubber crush and settle in.
There are generally two types of window felt: rounded stainless steel edged and flat edged. Rounded is more OEM like and costs about $40 more. Flat is the generic replacement and more common. If you donít care about the different in look, the flat will be fine.
I canít speak on fitment yet. I also bought it from GroundUp, and it is still sitting in the box as I try to wrestle my way through my window installation (found a bolt broken off in one of the mounting holes on the used door I bought and restored).
1968 Chevelle Malibu 454, mild cam, 30 over, 12-bolt 3.73 rear
1972 Chevelle Malibu 350, radical cam, 30 over, 10-bolt 3.55 rear
2007 Mustang GT, 4.6L (281), Stock
There are no Ford vs. Chevy wars in my garage. It's all U.S. muscle.
Proc is offline
post #5 of 9 (permalink) Old Apr 12th, 18, 9:14 AM
Mr Bill
The ones I got were also from GU and they did not fit worth a darn. I think I have a picture on my computer at home that shows the difference. The GU ones were a lot "thicker" than the oem ones and pushed the window in towards the interior. They told me to adjust the window to make up for it but then it would be pushing on the inner felt too hard. I sent them back and waited till I found some NOS ones.
I will try to find the picture tonight so you can see the difference.
Proc likes this.
Bill Koustenis
Waldorf Md
Team Chevelle #100
BillK is online now
post #6 of 9 (permalink) Old Apr 12th, 18, 10:47 AM
Stan
thanks
The pro custom interior shops use the correct type of foam and glue it directly to the underside of the roof. Then it is shaped and sanded to give the desired contour before the final material is glued to the foam. Quite common on many high end built custom interiors and for a small elky roof area, might be worth a try for a DYI.
How hot sun proof these are, you need to use the right glue I guess
stanski is offline
post #7 of 9 (permalink) Old Apr 12th, 18, 10:49 AM
Mr Bill
Here is a link to my old post that shows a picture of the new and old felts so you can see the difference. They might have fixed it by now.
https://www.chevelles.com/forums/45-c...dow-felts.html
Bill Koustenis
Waldorf Md
Team Chevelle #100
BillK is online now
post #8 of 9 (permalink) Old Apr 12th, 18, 9:15 PM
Rich
Crud.. I donít have the old ones any longer to compare against.
I just looked at them and they donít look like what you have pictured, so maybe Iím in luck.
Proc is offline
post #9 of 9 (permalink) Old Apr 12th, 18, 9:48 PM
rick
I bought repops window track felt/rubber and softseal weather stripping for the whole car from GU, only used the pas side window felt & vent rubber and seams ok but I remembered rubber on the outside of the door glass not felt so I cant give much advise I guess JMO, seems OK
shovelrick is online now
This Thread is more than 719 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
