67 Chevelle dash bezel - Chevelle Tech
 5Likes
post #1 of 16 (permalink) Old Dec 26th, 17, 3:53 PM Thread Starter
I was hoping to use the original plastic dashboard trim after it was vacuum chromed. Iím not sure this is going to happen now. All the chrome has worn to yellow but looked solid.
My radio bezel is in great shape. The dash had the original radio so the bezel and the dash were never modified for a new style radio. As I was removing the bezel above the glove box, one of the mounting pins sheared off. Itís already missing one. Can the pin that must sheared off be fused back onto the bezel?
How good are the reproduction bezels? I plan on enjoying my Chevelle by driving her and entering her in a few shows a year. How does the reproduction match up in looks (fit & finish) and will it hold up?
Iím unsure how much it will cost to vacuum chrome both items and if the missing and broken pins can be repaired.
1967 SS 396 Chevelle
Formerly Bolero Red
Soon to be a 427 equipped Tahoe Turquoise head turner!
Kopfjaeger is offline
post #2 of 16 (permalink) Old Dec 26th, 17, 4:06 PM
Re: 67 Chevelle dash bezel
My opinion the new reproduction pieces look way too chrome like/shiny/jeweled looking. Mine has been touched up prior to us owning in 20 years ago, and the surrounding edges are all painted sliver. I actually prefer that to the reproduction pieces, and if I got all new, I would do the same thing.
Pioneer4x4 is offline
post #3 of 16 (permalink) Old Dec 26th, 17, 4:25 PM Thread Starter
Iím going to need to purchase a reproduction upper bezel, the one that contains the ignition switch, light switch, lighter, and wiper switch. My original has two pins missing and Iíve yet to try and remove it!
If the reproduction ones look to chrome, I suppose I run the same risk having the original pieces vacuum chromes, although the place Iím using specializes in restoring items like this. Iíd hope they know how itís supposed to look. But there is the question of being able to repair the pins.
Formerly Bolero Red
post #4 of 16 (permalink) Old Dec 26th, 17, 4:44 PM
I guess on a SS with the crinkle black upper bezel, the chrome is more of an accent, and would look great. I mainly don't like the reproduction parts around the radio and above the glovebox.
Kopfjaeger likes this.
post #5 of 16 (permalink) Old Dec 26th, 17, 7:20 PM
Kevin
The reproduction bezels are only available in the black SS trim (last time I looked) and not the wood grain of the non SS models. The two are not interchangeable due to the switch locations being different.
My dash was not in good shape when I picked the car up. Thankfully the wood grain and dash pad were in excellent condition. I purchased reproduction parts for all of the rest, had some red lacquer with a flattening agent mixed for the stock dash color and everything looks really good in my opinion.
"If you're not living on the edge, you're taking up too much space" - Jim Whittaker
AFR Eliminator 195's
Inglese 50mm 8 stack injection
FAST XFI Street
SC&C Stage II Plus suspension
Hotchkis/Hellwig sway bars
Tremec TKO 600
Chevy67 is offline
post #6 of 16 (permalink) Old Dec 26th, 17, 8:11 PM Thread Starter
All the chrome is missing off the black ďswitch stripĒ. Itís also missing two pins so It has to be replaced. Guess Iím lucky I have an SS!
Iíve seen NOS radio bezels for sale but never a glove box bezel. My only option is vacuum chrome both pieces or replace both with reproduction. Iím guessing thatís what the majority has done in similar situations?
Formerly Bolero Red
post #7 of 16 (permalink) Old Dec 26th, 17, 8:20 PM
Just to clarify. The bezels from original SS cars & from original Malibu cars are almost completely different pieces. The SS strips are chromed plated plastic. The Malibu versions are two pieces, an aluminum bezel with a thin steel insert with a woodgrain applique.
The way the knobs are attached to the bezels are a bit different as well. The SS strips have the bezels molded into the strip. The Malibu strips have individual bezels for each knob. They are actually more substantial than the SS version.
I've posted a write up previously about converting a Malibu strip into an SS strip. All it takes is some time & a can of wrinkle finish black paint. I'll try to find the old thread.
64 2 door Wagon Build thread
67 2 door Sedan LS1 T56
Pete 67 is offline
post #8 of 16 (permalink) Old Dec 26th, 17, 8:45 PM
Here's the original thread...
https://www.chevelles.com/forums/26-i...ash-strip.html
davewho1 likes this.
Pete 67 is offline
post #9 of 16 (permalink) Old Dec 26th, 17, 10:14 PM
terry
I had a decal company overlay a black tape stripe on my wood grain one. Didn't remove the wood grain one so it has a texture to it...
The reproduction black ones don't come with the center a/c vent provision. Looks like you have a non a/c car, so this would be for future reference for others...
mytmouz is offline
post #10 of 16 (permalink) Old Dec 27th, 17, 7:45 AM
I knew there were differences in switch installations, but never knew that the actual black/woodgrain top pieces were made differently.
Thanks.
post #11 of 16 (permalink) Old Dec 27th, 17, 8:37 AM Thread Starter
Ed,
I took a real close look at your picture of your radio bezel. I do like that two tone look. While all the chrome is off my radio bezel, the black pinstripe is still there. Just like yours. Does anyone know if the reproduction pieces have that pinstripe/ black outline? The back side of the bezel is very shiny. I owned a one owner 67 Malibu back in the early 80ís but I really cant remember how the dash looked nor do I have pictures of the dash.
So, out of everyone out there with a 67, what did you do for your radio and above the glove box bezel?
Has anyone ever re attached a broken mounting pin? If so, what did you use?
Formerly Bolero Red
post #12 of 16 (permalink) Old Dec 27th, 17, 12:04 PM
Bill Wente
Thanks.
Just to clarify, the top strip switch LOCATION on '67 Malibu and SS is the same. But '67 locations are different than '66.
Originally Posted by Kopfjaeger View Post
Ed,
Yes, the repros have the black trim.
A few '67s and a '66
67since67 is offline
post #13 of 16 (permalink) Old Dec 27th, 17, 1:55 PM
Ed,
Thanks, as for the black stripe, for a while non had it, they were all 66 style I think, but I see them with stripe and groove patter of 67 now as well. Also I have heard that the reproduction ones do not line up as well, but I don't know first hand.
1967 El Camino Radio Bezel
post #14 of 16 (permalink) Old Dec 27th, 17, 8:19 PM
Shane
Any broken pins can be fixed with jbweld.
Don't be afraid to put it on there and then sand it off.
Drill some small holes in pieces you're trying to repair and shove the JB in there.
fishhead is offline
post #15 of 16 (permalink) Old Dec 28th, 17, 5:23 PM
Kevin
I used a reproduction radio bezel and while slightly off, it does line up pretty well with the piece above the glove box. I modified mine extensively so I could fit in a modern radio using a metal facia that I designed and had a friend cut on his water jet machine. Looks good and works even better.
From looking at my car, the 67 bezels have the horizontal ribs and black pinstripes while the 66's are more flat and don't match aesthetically with the surrounding trim.
FAST XFI Street
Tremec TKO 600
Chevy67 is offline
This Thread is more than 920 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
