Chevelle Tech - View Single Post - PST Front End Kit install, dialup warning
post #29 of (permalink) Old Jun 19th, 09, 8:56 PM Thread Starter
Tom Mobley
Re: PST Front End Kit install, dialup warning
Minor tip on steering linkage assembly: you can't install the center link if the Pittman arm and the idler arm are both installed. both studs go in from the bottom and with that tongue on the crossmember there's no way to get enough room. Leave the idler arm loose or off while mounting up the linkage. I laid my old linkage out on the ground and measured the length od the tie-rods, then screwed the news together to match. Considering the amount of stuff changed out here I'm surprised it came out as close as it did.
