Chevelle Tech - View Single Post - 13" Vette Rotors On Your Cars??
post #20 of (permalink) Old Feb 10th, 01, 5:41 PM
JERRY66SS
pdq67. Is your bracket totally flat with no offsets? In the junkyard I was looking at 70 impala rotors. They are 11 3/4" by 1 1/4" and are one piece and the spindle looks the same in the bearing area as the Chevelle/ Camaro. I got the caliper brackets from the 70 Impala and the caliper mounting area is the same as the Chevelle, also the brackets are made symetrically and can be switched side to side. I am thinking of revising these to fit. I don't want to cut up the set of Chevelle brackets I have, especially after seeing Master Power Brakes smacking people $100 apiece for theirs. First thing I need to do is get the 70 Impala rotors and see if that works then go from there. Have you tried my idea? Thanks, Jerry
JERRY66SS is offline
