Spark Plug Shields - Chevelle Tech
2003 General Tech Forum from 2003
post #1 of 4 (permalink) Old Jul 21st, 03, 11:04 PM Thread Starter
Eddie
Post Spark Plug Shields
I have seen a lot of restored 396 Chevelles, but they seem to be missing the spark plug shields that bolt to the manifold - any comments or pictures.
ecr69SSchevelle is offline
post #2 of 4 (permalink) Old Jul 22nd, 03, 12:47 PM
Bill R
Post
Ed, the primary function of spark plug shields is to reduce the amount of exhaust manifold heat that is absorbed by the ignition wires. Silicon wires and boots were not generally available, or used, thirty years ago. Shields are not necessary with the good quality wires that are available today. Spark plug shields are totally useless and tend to get in the way when headers are installed. Headers tend to be somewhat cooler than stock exhaust manifolds, because the heat is radiated better by the header tubes.
With that said, a restored engine with stock exhaust manifolds looks kind of naked without the heat shields - in my opinion.
64 Chevelle Malibu Sport Coupe (original owner) car now has 427" BB, Jerico 5-spd. trans., Dana 60 rear end.
SAE Member (25+ years)
ASE Master Certified Engine Machinist
AERA Certified Professional Engine Machinist
engineguy is offline
post #3 of 4 (permalink) Old Jul 23rd, 03, 2:30 AM
Post
Hi Ed, Agree with engineguy in every aspect. Adding to that, I put them in my '70 as it is a restoration. also a total pain to align for plugs.If I do it again it will be with the engine out for easier install. Necessary ? No, Points at a show? puts you a little closer to the top. Sorry I can't do the pics.yet. Brad
70ssgeg is offline
post #4 of 4 (permalink) Old Sep 29th, 16, 7:14 PM
lou
Send a message via AIM to roadster601
Re: Spark Plug Shields
hello did you ever install the heat shields on you 396 any pictures thanks
lou
roadster601 is offline
This Thread is more than 1337 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
You may not post new threads
You may not post replies
