Replacing “Vent / No Draft” Window on a 64 El Camino - Chevelle Tech
Tips & Fixes Helpful hints and solutions - no new topics.
post #1 of 3 (permalink) Old Sep 26th, 02, 5:26 PM Thread Starter
I have procured Soffseal weather stripping from OPG and even called Soffseal and no on knows how to Take and Replace and Install the Vent window and weather stripping.
Can You Help??
Steven K.
64elky's_Dad is offline
post #2 of 3 (permalink) Old Sep 26th, 02, 7:03 PM
No need to post it in three places!!!!!!
Leo Paugh
Maryland Chevelle Club #017
A.C.E.S.#3731
progress has little to do with speed, but lots to do with direction.
chev64 is offline
post #3 of 3 (permalink) Old Mar 25th, 05, 7:59 PM
mark
Re: Replacing “Vent / No Draft” Window on a 64 El Camino
you must remove the vent window frame frome the door.you will find the pivot rivetted to the frame.take a dremel with a cutting wheel and gently grind off the heads.remove the lower nut,spacers and spring.remember how they go back.replace your wstrip and reassemble,with small rivets.works great!
mino65 is offline
This Thread is more than 5232 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
You may not post new threads
You may not post replies
