Stupid Fuel Gauge - Chevelle Tech
Tips & Fixes Helpful hints and solutions - no new topics.
post #1 of 7 (permalink) Old May 12th, 02, 11:38 PM Thread Starter
Well, I have no idea what's wrong with it, but my fuel gauge doesn't want to work on my 71 Malibu. Needless to say I'm pissed off now and I've already died once. Any suggestions would help.
Cheetah015
p.s. I tried tracing the wires, but that's a pain in the..... well you know.
1971 Chevelle Malibu 350, 3-spd auto
Cheetah015 is offline
post #2 of 7 (permalink) Old May 13th, 02, 8:26 AM
Cheetah015, The fuel gauge works off grounding. Make sure the ground strap from the frame to the sending unit are clean. and where the wire to the gauge connects. Fuel gauge problems is many times no more than dirty connectors. Bob J.
Bob Johnson is offline
post #3 of 7 (permalink) Old May 13th, 02, 9:33 AM
It would help if you gave us a little more info. Did it ever work? Does it read empty or full all the time? Go here for a good troubldshooting procedure https://www.chevelles.com/techref/ftecref18.html
Steve Strasemeier (70SS 396, Fathom Blue/White Stripes)
My 70SS
Steve S is offline
post #4 of 7 (permalink) Old May 13th, 02, 7:22 PM Thread Starter
The fuel gauge is stays above 'full' and I've only had her for a couple of weeks so I'm not sure when it started. Thanks for your help
post #5 of 7 (permalink) Old May 14th, 02, 12:28 PM
Ron
<BLOCKQUOTE>quote:</font><HR>Originally posted by Cheetah015:
<HR></BLOCKQUOTE>
This is a classic no ground scenario - it has happened to me that the ground wire connector had rusted at the frame point, likely above the axle (not sure). My 2
Ron Cook TC Gold #1276 ___ ACES #5136
1969 300 Deluxe HTSS396 The L35-325HP 396cid 69 Memory Lane 1971 Malibu 2DR HT
CanAm Chevelle Club _____________"Take my advice, I'm not using it."
Bow_Tied is offline
post #6 of 7 (permalink) Old Dec 2nd, 06, 8:08 PM
Jack
Re: Stupid Fuel Gauge
If the guage stays pinned past full, it is very possible that the orange (or tan?) wire coming from your sender (Not the ground from the plate) is shorted to ground. I have purposely grounded this wire to test the function of the fuel guage; if it pins out past full while grouded, the guage and related wiring checks out ok and the problem is most likely ground. If it is pinning past full, check to make sure the sender wire isn't shorted somewhere. It sounds like that is most likely your problem; good luck!
jloshotz is offline
post #7 of 7 (permalink) Old Feb 10th, 07, 10:53 PM
Charlie
Cool Re: Stupid Fuel Gauge
I have a silly question. On a 68 chevelle do I have to remove the gas tank to check the connectors. psst keep this a
mart656 is offline
This Thread is more than 4537 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
You may not post new threads
You may not post replies
