rare or not - Chevelle Tech
2013 General Tech Forum from 2013
 2Likes
  • 1 Post By HP4251971LS6
  • 1 Post By Steve R
post #1 of 14 (permalink) Old Mar 18th, 13, 12:47 PM Thread Starter
David
Smile rare or not
I have just purchased a 1972 chevelle malibu by the bin it is a 350 2 bl sweep dash so its not an ss it does have a factory 12 bolt and front disc brakes my question is how rare is this " trailer option " from what I've found out most chevelles with this option were wagons however mine is a 2 door hardtop is this a rare package or was it pretty common just wanting to know if it is a rare optioned 2door or just a normal run of the mill malibu any annd all opinions and answers are and will be greatly appreciated
Chevelle_crazy72 is offline
post #2 of 14 (permalink) Old Mar 18th, 13, 1:27 PM
Re: rare or not
Your post is one very long run-on sentence, could you please use punctuation when posting? Is makes things a lot easier to read.
likes: candle light dinners, long walks on the beach, warm bubble baths.
dislikes: rude people, jealousy and bad breathe.
MalibuMike70 is offline
post #3 of 14 (permalink) Old Mar 18th, 13, 1:37 PM
Andy
Re: rare or not
Malibu Mike, was there a trailer package even available on a 70 2 door A body. I remember seeing a bunch of Sears installed air shicks and Class1 hitches, but nothing factory.
Andy's Auto Repair is offline
post #4 of 14 (permalink) Old Mar 18th, 13, 2:07 PM
Re: rare or not
Originally Posted by Chevelle_crazy72 View Post
I have just purchased a 1972 chevelle malibu ... does have a factory 12 bolt and front disc brakes ...mine is a 2 door hardtop is this a rare package or was it pretty common just wanting to know if it is a rare optioned 2door or just a normal run of the mill malibu
Chevrolet, in general, did not break down the options by bodystyle, therefore I don't think its really known if this is "rare" option for a 2-door, or even if its more "common" for a wagon.
The 12-bolt was a Heavy Duty item, and not a "Performance" option.
IMO, sounds like its just a run-of-the-mill Malibu ( 350-2barrel, sweep dash), despite the disc brakes and 12-bolt.
Do you have documantation showing the "trailering" option/12-bolt?
TC #1366
Sold
Sold
1966_L78 is offline
post #5 of 14 (permalink) Old Mar 18th, 13, 5:03 PM Thread Starter
David
Re: rare or not
No sir I don't. Sorry about the punctuation I was using my phone to post the question originally.It does not have a trailer hitch just the 12 bolt rear and the disc brakes .the only reason I am referring to it as a trailer package option is because that's what I've been told is why it has the 12 bolt and disc brakes up front. According to the vin it may or may not have the RPO option which is from my understanding is the SS package (could be wrong) .Also to my understanding there was no SS's produced with the sweep dash but seems like it would be a perfect candidate to clone an SS with.My knowledge on chevelles is very limited but I am learning little by little thanks to this forum and the other members here . Thanks for your patience with the "New Guy"lol
post #6 of 14 (permalink) Old Mar 18th, 13, 6:40 PM
Re: rare or not
There are no options coded in the VIN. You need some original paperwork to determine what are factory options. There was NOT a trailer option, tow hitchs were not factory options, aftermarket items/dealer accessories. If someone ordered the heavy duty radiator/cooling option V01, F40 Special Front and Rear suspension (F41=SS) or A/C with either of those then it probably defaulted to the HD rear axle. That was the way to build a car for towing or HD use (fleet).
elcamino is offline
post #7 of 14 (permalink) Old Mar 18th, 13, 6:58 PM
Re: rare or not
...the only reason I am referring to it as a trailer package option is because that's what I've been told is why it has the 12 bolt and disc brakes up front. According to the vin it may or may not have the RPO option which is from my understanding is the SS package (could be wrong) .Also to my understanding there was no SS's produced with the sweep dash but seems like it would be a perfect candidate to clone an SS with.
As was mentioned, there is no "SS" option (RPO) coded in the VIN. for 1969-1972 Chevelles, the SS package was an option that could be had on a 2-door "Malibu", therefore the VIN is the same as the Malibu (1969 is an exception as non-Malibus could also be SS cars). For 1972, the engine was denoted in the VIN, but the SS was available with a 350 a 402 (396) and the 454... The 350 and 402 were both available in the Malibu, but the 454 was only available with the SS...
Correct, no SS cars produced with the sweep dash, but the round pod dash (often called an SS dash) was also available in a plain Malibu (extra cost option) with guages. MANY Malibus had disc brakes, so the only "clone" part would be the 12-bolt, and many people don't see that, or don't know...
In earlier years, the 12-bolt was an option listing for trailering (usually in a non-performance gear ratio)...
Still a 12-bolt and discs are a nice start to a performance setup...
TC #1366
Sold
Sold
1966_L78 is offline
post #8 of 14 (permalink) Old Mar 18th, 13, 8:16 PM
Warren
Send a message via AIM to tar6569
Re: rare or not
I know on the fullsize cars in 70, there was an option for trailering ratio. Not sure if Chevelles had it.
1964-70 fullsize chevrolet research
tar6569 is offline
post #9 of 14 (permalink) Old Mar 18th, 13, 8:50 PM
Re: rare or not
http://www.chevellestuff.net/1972/options_by_model.htm
Dale's site lists RPO YD1, axle for trailering. It was available with all V8's (even the 307), and lists ONLY the 3.31 ratio 12-bolt (8.875" ring gear).
Elsewhere, the info alluded to
"with special suspension"
For what its worth, there were 2,821 Chevelles with this option in 1972... no breakdown of bodystyle. That does make it "rare", but doesn't necessarily mean it is "desirable", especially without documentation (beyond the value of now having a 12-bolt)... Positraction was optional...
TC #1366
Sold
Sold
1966_L78 is offline
post #10 of 14 (permalink) Old Mar 18th, 13, 9:57 PM Thread Starter
David
Re: rare or not
How would I get paperwork on the car? I have looked for the build sheet with no luck .As far as my plans for this car I'm putting in a 400 sbc with 97 vortec heads along with an elderbrock rpm air gap intake with a small cam and using a 350 turbo tranny .Should be a stout street car.
post #11 of 14 (permalink) Old Mar 19th, 13, 12:29 AM
Cam
Cameron Milne
Re: rare or not
Not super common, but definitely a plus. A YD1 Trailering Rear Axle, 3.31 12-bolt is desirable and is a good ratio for where it sounds like you are going with your new Chevelle. Build that TH350 well so it can live behind aggressive use from your 400. It sounds like a great package. Congrats!
"The more you know,
TC Gold #120
Cam is offline
post #12 of 14 (permalink) Old Feb 7th, 18, 8:57 AM
Re: rare or not
These are the known Regular Production Option codes, otherwise known as RPO codes.
It is important to note the items listed and the quantity represent the item individually when ordered as an option and not when they may have come as standard equipment or in a convenience or appearance group on certain models. The cost listed is the price in 1970/1971.
1971 Chevelle Option / RPO Codes:
Code Description Quantity Cost
A01 Soft Ray Tinted Glass - All Windows 370,582 $43.20
A02 Soft Ray Tinted Glass - Windshield 6,827 N/A
A31 Power Windows 10,774 N/A
A33 Power Rear Window 18,479 N/A
A39 Deluxe Seat Belts, Front & Rear 799 $13.20 - $14.75
A41 Front Seat Electric Control - 4-Way (w/ Bench Seat) 1,174 N/A
A46 Front Seat Electric Control - 4-Way (w/ Strato-Bucket Seats) 1,186 N/A
A51 Strato-Bucket Seats 52,638 $136.95
A85 Deluxe Shoulder Harness 72 $26.35
A90 Power Rear Compartment Lid Release 3,060 N/A
AK1 Deluxe Seat Belts & Front Seat Shoulder Harness 91,887 $15.30 - $16.90
AQ2 Electric Seat Back Lock Release 195 N/A
AS4 Deluxe Rear Seat Shoulder Harness 245 $26.35
AU3 Power Door Locks 6,430 $46.35 - $70.60
B37 2 Front & 2 Rear Color-Keyed Floor Mats 127,473 $12.65
B85 Belt Reveal Molding 24,174 N/A
B90 Door Window Frame Molding 9,547 $26.35
B93 Door Edge Guards 170,733 $6.35 - $9.50
C05 Folding Top 5,089 N/A
C08 Vinyl Roof Cover 240,635 $64.60 - $94.80
C50 Rear Window Defroster 36,416 $31.60 - $36.90
C51 Air Deflector 9,239 N/A
C60 Deluxe Air Conditioning (1) 311,464 $407.60
D33 Remote Control Outside LH Mirror 97,133 $12.65
D34 Vanity Visor Mirror 26,334 $3.20
D55 Front Compartment Console 46,614 $59.00
D88 Sport Stripes 13,382 $79.00
F40 Special Front & Rear Suspension 17,711 $17.95
F41 Special Performance Front & Rear Suspension 16,431 $30.55
G67 Rear Shock Absorber Level Control 2,297 N/A
G80 Positraction Rear Axle 33,994 $46.35
J50 Power Brakes 124,996 $47.40
JL2 Front Disc Brakes 83,868 $69.55
K30 Speed & Cruise Control N/A $63.20
K85 63 Amp Delcotron Generator 3,620 $5.30 - $26.35
L48 270 hp Turbo-Fire 350 Engine 78,711 $73.75
L65 245 hp Turbo-Fire 350 Engine 119,379 $26.35
LS3 300 hp Turbo-Fire 402 Engine 17,656 $172.75
LS5 365 hp Turbo-Jet 454 Engine 9,502 $279.10
M11 3-Speed Transmission 2,511 $132.00
M20 4-Speed Wide-Ratio Transmission 9,786 $195.40
M22 Heavy Duty 4-Speed Close-Ratio Transmission 3,035 $237.60
M35 Powerglide Transmission 66,625 $179.55 - $190.10
M38 Turbo Hydro-Matic Transmission, TH350 402,488 $216.50
M40 Turbo Hydro-Matic Transmission, TH400 21,333 $216.50 - $306.25
MC1 Heavy Duty 3-Speed Transmission 548 $132.00
N33 Comfortilt Steering Wheel 41,853 $45.30
N40 Power Steering 477,812 $115.90
NK2 Deluxe Steering Wheel 1,898 $15.80
NK4 Sport Steering Wheel 8,962 $15.80
P01 Bright Metal Wheel Covers 208,162 $26.35
P02 Simulated Wire Wheel Covers 8,392 $84.30
P90 G70-15-B G/B White Stripe Tires 22,904 N/A
PA3 Deluxe Wheel Covers 24,009 N/A
PK2 G78-14-B G/B White Stripe Tires 16,807 N/A
PL3 E78-14-B B/B White Stripe Tires 153,912 $28.15
PM6 G78-14-D G/B White Stripe Tires 11,587 N/A
PM7 F60-15-B G/B White Letter Tires 19,542 N/A
PU8 G78-15-B G/B White Stripe Tires 101,428 N/A
PX5 F78-14-B B/B Blackwall Tires N/A $17.95 - $23.20
PX6 F78-14-B G/B White Stripe Tires 113,593 $48.10 - $53.35
T58 Rear Wheel Opening Skirt 17,602 N/A
T60 Heavy Duty Battery 36,319 $15.80
U14 Special Instrumentation (2) 16,994 $84.30
U35 Electric Clock 42,174 $16.90
U63 Push-Button Control Radio 423,833 $66.40
U69 Push-Button Control AM/FM Radio 39,079 $139.05
U76 Windshield Antenna 510,724 N/A
U79 Stereo Equipment 7,894 $239.10
U80 Auxiliary Rear Speaker 90,512 $15.80
UM1 Push-Button Control Radio & Tape Player 22,164 $200.15
UM2 Push-Button Control AM/FM Radio & Tape Player 3,922 $372.85
V01 Heavy Duty Radiator 5,353 $14.75 - $21.10
V30 Bumper Guards 37,640 $16.15 - $31.60
V55 Luggage Carrier Equipment 17,121 N/A
YD1 Trailoring Axle 1,633 $12.65
YF3 Heavy Chevy Package 6,727 $142.20
Z15 SS Equipment 19,293 $357.05
Z20 Monte Carlo SS 454 1,919 N/A
ZJ7 Special Wheel, Hub Cap, & Trim Ring 109,037 $45.30
ZJ9 Auxiliary Lighting Group 36,996 $15.80 - $23.70
ZL2 Special Ducted Hood Air System 4,079 $158.00
ZP5 Appearance Group N/A $53.80 - $56.95
ZQ2 Operating Convenience Group N/A $16.90 - $66.45
ZQ9 Performance Ratio Rear Axle 302 $12.75 - $33.75
703 Trim Vinyl Coated 16,775 N/A
705 Trim Vinyl Coated 69,826 N/A
714 Trim Vinyl Coated 39,475 N/A
721 Trim Vinyl Coated 35,036 N/A
726 Trim Vinyl Coated 1,945 N/A
731 Trim Vinyl Coated 43,613 N/A
956 Two-Tone Exterior Paint Combinations 5,991 $31.60
960 Two-Tone Exterior Paint Combinations 4,150 $31.60
968 Two-Tone Exterior Paint Combinations 3,140 $31.60
969 Two-Tone Exterior Paint Combinations 4,511 $31.60
971 Two-Tone Exterior Paint Combinations 2,090 $31.60
977 Two-Tone Exterior Paint Combinations 3,685 $31.60
1 - Includes heavy duty radiator, temperature controlled fan, 63-amp generator.
2 - Includes tachometer, ammeter, temperature, and oil pressure gauges.
Steve R likes this.
HP4251971LS6 is offline
post #13 of 14 (permalink) Old Feb 7th, 18, 9:58 AM
Re: rare or not
I remember finding a 70 Monte Carlo in a SoCal pick a part back in the late 80ís, it was a 350 2-barrel but had a 12 bolt posi with 2.73 or 3.07 gears. Looked like it was an all original grandma car.
Video:
fr8dog is offline
post #14 of 14 (permalink) Old Feb 7th, 18, 10:05 AM
Re: rare or not
About a dozen years ago I bought a 68 El Camino that originally had a 307, 4spd, factory tach and gauges along with a 12 bolt posi. I have no way of knowing if the rear end was original to that car, but it was from a car that had air shocks.
Steve R
fr8dog likes this.
Steve R is offline
This Thread is more than 673 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
You may not post new threads
You may not post replies
