Forget about driveline angles... - Page 3 - Chevelle Tech
2014 General Tech Forum from 2014
post #31 of 73 (permalink) Old Jan 16th, 15, 3:48 AM
Re: Forget about driveline angles...
Originally Posted by andrewb70 View Post
NASCAR has no use for them since they position the engine so that driveline angles are minimal, in other words, they don't need them. I bet it is also against the rules.
I've found that most drag racers don't worry about vibrations because they make a pass and that, that. The short duration of whatever vibration they might have is tolerable.
What's not tolerable is driving for 500 miles at 75 MPH and feeling the vibration for 8 hours.
Andrew
That is kind of my point about it being against the rules.
If the rules state in NASCAR what all angles are. Why would they need that anyway.
Even though NASCAR now has black boxes and has engine mapping and EFI, that can not be messed with once the race starts. Meaning its entirely in the drivers hands and what he feels in the car and relates that back to the crew chief for changes on pit stops.
True on drag racers.
Would this explain why you dont see vettes much on a drag strip?
I have a set of slapper bars on my 99 silverado in which Im thinking Im getting some kind of vibration due to the slapper bars and pinion angle working against each other. Its a leaf spring set up. Drives fine under 75. Once you get up over that, you get a vibration. Im wondering if the pinion is wanting to rotate more up and snubbers are getting jammed up into the leaf at that high of a speed. The rear gear is a 4.56 and has a T56 in front of that. Crusie rpms are about 1500 to 1800 at about 70 rpms. Im wondering if Im going to have to lengthen the distance between the snubbers. Already done that one.
That is correct. That is not tolerable with that kind of vibration for that amount of time.
Another way to look at what your doing there is this. You speak of 21st century technology. Why are you messing with a older bodied car? I can tell you why. They have alot more balls than newer ones!
Aaron is offline
post #32 of 73 (permalink) Old Jan 17th, 15, 8:00 PM Thread Starter
Andrew
With regard to your Silverado, how long is the driveshaft, what's the material? With 4.56 gears you might be getting close to the critical speed.
Andrew
Instagram @projectgattago
Please get in touch for Holley EFI tuning services.
andrewb70 is offline
post #33 of 73 (permalink) Old Jan 17th, 15, 9:40 PM
Dont recall right off hand.
I would have to measure.
The mechanic who rebuilt the trans thinks this might be due to incorrect u joints. That has been a pain.
Its a Dynatech piece. Made of aluminum.
The driveshaft is suppose to be rated for speeds up to 150 mph I think or somewhere around there.
Aaron is offline
post #34 of 73 (permalink) Old Jan 19th, 15, 12:56 AM Thread Starter
Andrew
Wish I could help, but not a lot of detail to go on.
Andrew
post #35 of 73 (permalink) Old Jan 19th, 15, 10:27 AM
Andrew
I answered your questions. You dont state what more detail you want. Thats ok, it, may just be the improper u joint. It seems Dynatech and the agreement they have Spicer, as this the brand they use when you receive the driveshaft, just might be the issue. Spicer does not release there part numbers to other sources. You have to go to a Spicer dealer. However, you have to a part number, the Spicer dealer here does not measure them. I figured heck why can someone just measure the old Spicer joint and go with what your local parts store can get, but after watching and listening to the transmission rebuilder he might be right on his theory that the new u joints in the driveshaft are the issue. I have not looked at the u joints that are in the driveshaft now, just picked up the driveshaft and installed it. Did not notice anything wrong or off on the install. I guess this will be correct or eliminated over the course of trial and error and examining all the componets involved.
Aaron is offline
post #36 of 73 (permalink) Old Jan 19th, 15, 10:43 AM Thread Starter
Andrew
I asked for the length of the driveshaft...
I don't see how a u-joint can be "wrong" and still be installed. U-joints are either the right one for the application or they aren't.
Here is a complete Spices (Dana) u-joint guide:
http://www2.dana.com/expertforms/dek350.aspx
Andrew
post #37 of 73 (permalink) Old Jan 19th, 15, 12:24 PM
Andrew
I know that Andrew. I would have to measure the length for you, I dont remember right off hand.
I didnt really follow what he had to say, but he made it sound like clips where left or something and it does seat right or something. I have to see what he is talking about with my eyes first to be able to describe it better.
Aaron is offline
post #38 of 73 (permalink) Old Jan 20th, 15, 7:48 PM Thread Starter
Andrew
Here is an aluminum version that Ken just installed in his LSA powered 66:
His front operating angle was 8 degrees, full Ridetech suspension system.
His full build can be read here:
http://ls1tech.com/forums/conversion...onversion.html
Andrew
post #39 of 73 (permalink) Old Jan 28th, 15, 4:51 PM
Gerry
Andrew
Great information!
How much horsepower do you think one of these combos can safely take? My current drive shaft is 58-1/2" long using 1330 U joints.
67 SS BBC
4.11's
bradley67 is offline
post #40 of 73 (permalink) Old Jan 28th, 15, 4:57 PM Thread Starter
Andrew
Originally Posted by bradley67 View Post
Great information!
The CV joint is not the limiting factor for power handling. The shaft that went into Ken's Chevelle has a 1350 joint on the rear, which I suspect will break before any other part.
Andrew
post #41 of 73 (permalink) Old Mar 9th, 15, 10:01 PM
Kirk
One quick question would this help lower the transmission and make the tunnel cutting a little less drastic? I'm going with an LS2 and T56 magnum in my 70. If this helped with vibration and tunnel surgery I would be willing to part with the 1 grand are asking price.
Is the below link all inclusive?
http://www.driveshaftshop.com/domest...-or-muscle-car
chevy111 is offline
post #42 of 73 (permalink) Old Mar 9th, 15, 10:14 PM
That is the right solution if you can't or are not willing to get the tunnel wide and high enough for correct angle. I ended up with -1degree of angle on my driveshaft and will be able to use the regular setup now. That solution was more time and work but cheaper than this high dollar CV shaft plus raising the tranny gives me much better ground clearance. The driveshaft shop piece is a great piece though and I know will work with as much as 6 degrees of angle.
Bill Howell is offline
post #43 of 73 (permalink) Old Mar 10th, 15, 12:24 AM
Kirk
The only thing that worries me was the fact that some were saying the driveshaft would hit the middle floor support. I'm not sure how to solve that and if cutting the brace would weaken the floor structure substantially. Then again I'm sure some extra support could be welding in. I do like the fact it is a newer designed shaft since I'm attempting to update the drivetrain. The price is high and is the only factor to try and use an older style driveline.
chevy111 is offline
post #44 of 73 (permalink) Old Mar 10th, 15, 1:30 PM
Yes, you have to cut and rebuild that brace. We made that our driveshaft loop so it worked fine.
post #45 of 73 (permalink) Old Mar 10th, 15, 10:55 PM Thread Starter
Andrew
The CV is about 4.25" in diameter, which is not much bigger than a 1350 u-joint yoke. The possible interference with the brace largely depends on what transmission you are using.
Is your u-joint positioned right at the brace?
Andrew
This Thread is more than 1777 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
You may not post new threads
You may not post replies
