Any experience rebuilding L31 Vortec engines? - Page 2 - Chevelle Tech
2014 General Tech Forum from 2014
post #16 of 23 (permalink) Old Oct 1st, 14, 4:26 PM
Dennis
Re: Any experience rebuilding L31 Vortec engines?
Well if you already have the heads and intake then you can also look into the tbi engines that have the one piece rear seal with roller cam. I took a chevy 350 out of like an 93 buick roadmaster and the short block builds just like an old school 350, I honed it, put new rings in it, got a bigger cam off ebay and reused the roller lifters and spider. I had under 1200 bucks in the rebuild and 600 of that was the engine from a junk yard. Any of the passenger cars had the roller cams like from 88-95 or so. tbi truck engines have flat tappet cams.
pics of projects and whatever.
ddeennis is offline
post #17 of 23 (permalink) Old Oct 1st, 14, 10:05 PM Thread Starter
duane
Thanks, that is an excellent tip! Somewhere in my L31 research I read that the 96+ had the roller cam/spiders, and of course the 1 pc sealing setup. I didn't realize the earl 90 Roadmaster SBC had the roller cam setup, thought that was 95+. I know that many of those Roadmasters had the LT4 reverse cooling setup, which I don't want as it won't play with my Vortec setup.
I'll do some research on the Buicks, perhaps that is the ticket to finding a low mile block (Gpa car) without the L31 prices.
DET17 is offline
post #18 of 23 (permalink) Old Oct 1st, 14, 10:58 PM
Early 90s impalas, trucks, etc will all have the 1 pc seal block, and though all may not have factory roller lifters, the spider and OE style lifters can be installed.
Another important tip: make damn sure that the block has provisions for a mechanical fuel pump if that's important to you. Many of them don't. Not something you want to learn when it is already built and in your car.
novadude is offline
post #19 of 23 (permalink) Old Oct 1st, 14, 11:47 PM
If you already have the Vortec heads + intake, and want to build a roller cam engine, then any 87-99 block will be roller-cam capable. They made a gazillion trucks with them from 87-99. Camaro/Corvette 87-92, Caprice (not LT1). Not hard to find, it will just be a matter of how much you want to pay.
If you buy a flat-tappet equipped engine, you will have to find a spider, dogbones, and cam retainer plate. Also, pushrods are different length, since the roller lifters are taller.
-Dave
'70 Chevelle ZZ383/700r4/3.73, [email protected] -- MS3X efi / Hotchkis A-arms & Springs / B-body 12" brakes / 1.25" F-body swaybar / UMI rears & swaybar / JGC PwrStrUpg
ChevelleFan70 is offline
post #20 of 23 (permalink) Old Oct 2nd, 14, 6:59 AM Thread Starter
duane
Going EFI, no worries about the fuel pump.
DET17 is offline
post #21 of 23 (permalink) Old Oct 2nd, 14, 7:29 AM
First place to look to save a lot of work is at your machinist's shop. Many keep bare block cores in stock and will make you a decent deal on it since they know they'll have a shot at machining and parts sales. Sure beats pulling and tearing a few down only to find out they're junk or not what you're looking for.
Gary Adrian
Busted Knuckles is offline
post #22 of 23 (permalink) Old Oct 2nd, 14, 5:02 PM Thread Starter
duane
Good thought.....my local guy has a row of shortblocks at the front of his store, but all were finished, filled, and ready for heads. I might just ask him if he has any cores that would be suitable for my rollercam SBC project.
DET17 is offline
post #23 of 23 (permalink) Old Apr 24th, 16, 2:42 PM
seth
I have a l31 in my Chevrolet out of an express van my biggest complaint is the timing chain cover and oil pan setup. They are hard to get to seal.
bull600 is offline
This Thread is more than 1505 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
You may not post new threads
You may not post replies
