How much HP can a stock 454 bottom end handle? - Page 2 - Chevelle Tech
2014 General Tech Forum from 2014
 3Likes
post #16 of 26 (permalink) Old Sep 19th, 14, 4:44 PM
Paul
Re: How much HP can a stock 454 bottom end handle?
I doubt there is a better web-site for BBC combo's then this one... I think I read thread after thread for about 2 years before deciding on mine.
Good luck and keep us posted on how it turns out.
454/T400/9" in a 67 Beaumont
Paul-ish is offline
post #17 of 26 (permalink) Old Sep 19th, 14, 10:05 PM
rick
Theres no replacement for displacement (cubes) I put a 86 winnie 454 T-400 with a rebuilt 3:73 12 bolt posi in my 68 mali, crane energizer 282 , 750 holley dbl pump, and 063 heads (not done yet) torque monster!, ya cant go wrong with one of these because theres so much you can do with them
Name:	2012-05-04 18.44.31.jpg
MarkP likes this.
shovelrick is offline
post #18 of 26 (permalink) Old Sep 20th, 14, 1:08 AM
George
Nice RAT Recipe (Super Budget 454 series from 2009)
1975ish dish piston shortblock; clean and dingle hone
new rings, bearings, gaskets
1968 closed chamber oval heads
226*/.522/108 Crane/Summit cam
old Eddy C396QJ intake
800DP Holley
4000# 70 Elky and driver 2400 stall 3.42s= 13.oh
same combo but 3000 stall = 12.7s! with more in it
raced it one year
it has been in a boat since 2010, guy that bought it loves it!
if I were todo it again, would run the zz502HR cam
same combo but 3000 stall= 12.7s!
George Kettler
o 68 Vette 427/M-20/3.36 28 year owner
o 68 Camaro Vert 327 project, painted, assembly stage
kettbo is offline
post #19 of 26 (permalink) Old Sep 20th, 14, 11:23 AM
I have built a few big block 496 and 454 engines and such that are 2 bolt mains that are at that power level or a little above. Its always better to run forged rods if you can, also put studs in the mains for any rpms pushing 6k.
Mike 70SS is offline
post #20 of 26 (permalink) Old Sep 20th, 14, 9:39 PM
George
Mike, all factory BBC rods are forged.
Where people used to get into trouble were the bad factory shifters. Miss a shift and bad things can happen...maybe the first time...maybe the 22nd time. Missed shifts tended to challenge the stock rod bolts. Automatic cars through 5500rpm and 454s are pretty safe with the stock bolts. 396/427 shorter stroke is less taxing then 454 longer stroke so I'd not be worried about 6000 rpm. ANY shift-thyself std trans I'd be sure to get good rod bolts in there and resize the big ends.
Factory rods order of merit:
passenger car, big end is dog bone shaped
truck rod, big end stays narrow and your thumb fills the gap hence "thumb rods"
factory HP rods, have a 'dimple' more exactly a ZIT toward the small end 3/8 early or 7/16"
George Kettler
kettbo is offline
post #21 of 26 (permalink) Old Sep 20th, 14, 11:54 PM
Obviously installing new rod bolts is an easy call but can factory HP dimple rods with 3/8 bolts get upgraded to 7/16 and is it worth the upgrade for a typical street/strip build ? Also between forged and hypereuretic 454 pistons with similar sized domes which would be lighter ?
71 El Camino SS
406 SBC M21 3.31 12 bolt
71350SS is offline
post #22 of 26 (permalink) Old Apr 10th, 15, 10:55 AM Thread Starter
stan
Is it necessary to sonic test the block for a 500 ish hp build?
1969 Chevelle 300 454! finally, 29-3200 stall, TH400 and moser 12 bolt 3.73 gears.
2011 Chevy Colorado crew cab 5.3L ZQ8 black on black
ACES#7897
69355 is offline
post #23 of 26 (permalink) Old Apr 10th, 15, 11:00 AM
I have a 454 that was built 14 years and 25K+ miles ago,made around 490 HP at the crank and was not sonic tested.
mr 4 speed is offline
post #24 of 26 (permalink) Old Apr 10th, 15, 11:57 AM
jeff
Stan, if you are gonna bore it out, I would have it sonic tested... Not all blocks are the same,some might have had a core shift when they were made in the foundry, jmo...
jeffs68 is offline
post #25 of 26 (permalink) Old Apr 10th, 15, 12:06 PM Thread Starter
stan
Don't plan on boring it out. Just curious if that's a mandatory step to take before building up a big block.
ACES#7897
69355 is offline
post #26 of 26 (permalink) Old Apr 10th, 15, 12:35 PM
jeff
Your block will need to be thourghly cleaned because of your wiped out cam,metal pieces will be all over the inside of your block...
MarkP likes this.
jeffs68 is offline
This Thread is more than 1880 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
You may not post new threads
You may not post replies
