Gen 6 HR cam in a Mark IV??? - Page 4 - Chevelle Tech
2014 General Tech Forum from 2014
post #46 of 55 (permalink) Old Apr 8th, 14, 9:41 PM
Re: Gen 6 HR cam in a Mark IV???
If it spins free I would be happy but there is no good reason not to give it a little clearance if it makes you feel warm & fuzzy
I think you will find if you put an indicator on it & lightly pry the cam back & forth you will find you actually have clearance if it rotates freely
Mike (Wolfplace)
VISIT US AT
----John Wayne----
Wolfplace is offline
post #47 of 55 (permalink) Old Apr 9th, 14, 10:46 AM
Dale
John, it sounds like you're getting it to work but just a thought-
Did you verify that the bearing is seated against the gear? If I remember
correctly, you can check this easily with feeler gauges.
66 Chevelle
1/8 mile
1/4 mile
Building more of a race car than driver but driving it more than I race. "simple old school shake, rattle & roll".
Monk is offline
post #48 of 55 (permalink) Old Apr 9th, 14, 2:18 PM Thread Starter
I'm no expert on how to install a torrington bearing! This came installed and it appears to be seated all the way- how do I know for sure?
1970 Monte in the 11s
1968 Camaro in the 10s
Street Cars are More Fun!
jburns is offline
post #49 of 55 (permalink) Old Apr 9th, 14, 3:09 PM
Dale
I wouldn't get too excited over it since everything is very close as is, but if you want to check, see if you can stick a .002 feeler between the mating surfaces where the bearing is pressed up against the gear.
66 Chevelle
1/8 mile
1/4 mile
Monk is offline
post #50 of 55 (permalink) Old Apr 9th, 14, 4:24 PM
Dwight
I did not have time to read this whole post but I had the same problem this last winter. I used a valve spring shim between the cam gear and cam. I used my die grinder to grind three reliefs for the bolts then sandwiched it between the gear and the cam. I think the one I used was .015 and I went from having to use a wrench on the bolts to turn the cam to spinning it easily.
SeventyLS5 is offline
post #51 of 55 (permalink) Old Apr 9th, 14, 8:59 PM Thread Starter
Thanks- I went for the warm and fuzzy! There really was zero end play per my dial indicator. My machinest at work gave me exactly .002 on the indicator... time to get this thing running!
jburns is offline
post #52 of 55 (permalink) Old Apr 9th, 14, 10:29 PM
Mac
Glad ya got it figured out
1970 Chevelle SS full weight street car (4030lbs)
498-11.5:1 (Mac built) 91 pump gas+
Strauby sissy roller -
brodix-rr rec 294
weiand stelth- Pro Systems 1000
turbo 400 10" 3200 Coan 4.10 12 bolt
Best Passes on28-10.5-15 slicks and 110
1.56-6.97-99.83
1.6194-11.1666-120.94
And a drag [email protected]
If it wasn't dangerous, it wouldn't be fun!
bigmachd is offline
post #53 of 55 (permalink) Old Apr 10th, 14, 9:23 AM
mr 4 speed is offline
post #54 of 55 (permalink) Old Jun 30th, 14, 2:47 PM
This is a great thread.
I had the same problem on my MK. IV block with Gen 6 nose H.R. and rollmaster cs2095 timing set. When I bolted the cam gear onto the camshaft and tightened the bolt, the cam gear pulled snug against the thrust plate. Solution was to install shim between cam and cam gear. I'm still playing with thickness of the shim to get the endplay within reason. And yes, the crank gear is a little bugger. Just when you think its on all the way......it wasn't. Needed bigger hammer on that too!
Video:
fr8dog is offline
post #55 of 55 (permalink) Old Mar 9th, 16, 6:01 PM
I am having the same problem with the same setup. I found that the Torrington bearing inner race is hitting the thrust plate and plate ID needs to be opened up just past the 3 retainer tabs that hold the bearing together like the OP did to his. Another pain in the butt as I have 6 of these to do.
Brian41 is offline
This Thread is more than 1586 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
You may not post new threads
You may not post replies
