Re: Rear left wheel locked up
[QUOTE=Rich-L79;5654274]Uh, Gary, I was responding to specific question he asked in the post just prior to my post.
But wouldn't that prevent the wheel from moving in both directions?[/QUOTE]
Depends on what broke ? ,I had the pinion nut fall off of my 69 SS while going around a turn and the rear end locked and then the car skidded to a stop.I was only going about 15-20 and making a turn on a city block,so damage was minimal but terminal.My point is I was able to push it backwards into a corner parking spot but it would lock up rolling forward again.
But
That was with both wheels locking up,in this case with only one wheel locking up it most likely is a brake issue.
Don't rule out a hydraulic problem, when the rear brake hose goes bad it can cause a drag on the rear brakes till they heat up and lock.Then the one with the tightest adjustment will lock up first.
If its a rusted & seized brake cable it will be locked up all the time and if it's over adjusted it will be the locked up all the time.If it's a hydraulic problem (brake hose) it will get worse the more you drive the car and the hotter the brakes get.
71 El Camino SS
406 SBC M21 3.31 12 bolt
