jacking points - Chevelle Tech
2014 General Tech Forum from 2014
post #1 of 11 (permalink) Old Feb 19th, 14, 11:08 AM Thread Starter
jacking points
Could someone show or tell me the jacking points on a 70 Chevelle. Don't want to use the factory jack. Thanks
Dave Birchmire, Sr.
1970 SS-454
dbirchmire is offline
post #2 of 11 (permalink) Old Feb 19th, 14, 12:00 PM
Re: jacking points
Anywhere under the frame, front xmember, rear differential, under the Aframes, etc...
oldcutlass is offline
post #3 of 11 (permalink) Old Feb 19th, 14, 3:09 PM Thread Starter
Re: jacking points
Dave Birchmire, Sr.
1970 SS-454
post #4 of 11 (permalink) Old Feb 19th, 14, 4:35 PM
Derrick
Re: jacking points
not anywhere under the frame- jack it up NASCAR style under the door and you will bend the frame rail...
the proper places are behind the front wheels and in front of the rear wheels where the frame turns in and under the front engine crossmember and center section of the rear differential..
-Hank Hill
novaderrik is offline
post #5 of 11 (permalink) Old Feb 19th, 14, 4:35 PM
Re: jacking points
If like a 71, NOT under what looks like C-channel part of frame. Factory manual shows correct locations fore and aft of what looks like your basic ladder frame side rails. (One of the correct areas includes a big hole. Which may have been used to locate the frame on the assembly line?) Suggest painting them a contrasting color, and noting this to anyone else working on the car.
dogsridewith is offline
post #6 of 11 (permalink) Old Feb 20th, 14, 1:18 PM
Rich
Re: jacking points
Dave,
Your signature says that you have a big block so you need to exercise caution when jacking up the car. If you jack up behind the front wheels, the weight of the engine will flex the frame down enough so that if you open the front doors, the leading edge of the door will scrape against the fender and you will lose some paint along that edge. If you need to get inside the car while up on jack stands, place your jack under the front cross member and provide enough support to eliminate the flex.
Rich
Big White is offline
post #7 of 11 (permalink) Old Feb 20th, 14, 6:11 PM Thread Starter
Re: jacking points
Thanks guys !!
Dave Birchmire, Sr.
1970 SS-454
post #8 of 11 (permalink) Old Feb 20th, 14, 7:44 PM
Keith
Re: jacking points
Originally Posted by Big White View Post
Dave,
Rich
How rusted is your car. I never had that problem in my 66 SS
Maryland Chevelle Club #682
keithb is offline
post #9 of 11 (permalink) Old Feb 21st, 14, 10:55 PM
Re: jacking points
Dave,
Rich
Neither one of my 70's has ever done that, both are big block cars and one a convertible.
BlueSS454 is offline
post #10 of 11 (permalink) Old Feb 22nd, 14, 7:06 PM
Rich
Re: jacking points
It's not an uncommon problem. Do a search and you'll see. Perhaps your door gaps are wide enough for a non-interference fit. It doesn't take much.
post #11 of 11 (permalink) Old Feb 22nd, 14, 7:45 PM
Re: jacking points
I've jacked the car up and down both sides, and place jack stands in different locations based on where I'm working underneath. I have a BBC in it and never flexed a frame. Unless the frame is really weak due to corrosion, I see no issues.
This Thread is more than 2292 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
You may not post new threads
You may not post replies
