test - Chevelle Tech
Test Drive New to this area?
Test post and edit your own messages.
post #1 of 1 (permalink) Old Jun 17th, 07, 1:13 PM Thread Starter
Steve Johnson
test
x
1970 SS with a .030 over 454 LS6 crate engine, 14096188 open chamber rect. cast iron heads, 3933163 intake, Quick Fuel Q850PV, Summit 110gph FP, Holley 12-803 fuel pressure regulator set to 6.5 psi, Bullet cam (238/245 @ .050, lift 540/540, LSA 109), Gm HEI 93440806, TH400, FTI 3500 convertor, Hedman headers, 2.5" exhaust with H-pipe, Pypes Race Pro mufflers, 3.55 gears, KYB gas shocks, UMI rear adjustable upper control arms and UMI boxed lowers, pinion angle negative 1-2 degrees), 225/70/14 Cooper Cobra GT's and M/T Pro Bracket Radials, timing total 37 degrees. Best 1/4 mile pass 1.700 60', 11.841 @ 111.73 mph
Steve Johnson is offline
This Thread is more than 4628 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
