350 5.7L won't start after spark plug change - Chevelle Tech
post #1 of 19 (permalink) Old Jul 26th, 17, 8:08 AM Thread Starter
I have a 1970 chevelle 4 door that I am trying to get to a solid running state. I have fresh gas in it and gas is flowing to the carburetor. I just replaced battery and alternator and I'm getting 12 volts so that's good. It would idle fine before I changed spark plugs. Why is it not starting anymore? Thanks.
brandonnoah19 is offline
post #2 of 19 (permalink) Old Jul 26th, 17, 8:19 AM
Andy
Re: 350 5.7L won't start after spark plug change
Check your choke.
Andy's Auto Repair is offline
post #3 of 19 (permalink) Old Jul 26th, 17, 8:32 AM
steve
is that all you touched? the spark plugs?
71 malibu 6spd 6.0 procharged
2011 streetglide stage 1- sold
05 F350 dually- 602 HP 853 ft lbs torque
former KC-10A Chief-"Our Goal Is Your Hole"
71'bu is offline
post #4 of 19 (permalink) Old Jul 26th, 17, 8:42 AM Thread Starter
Where is that?
post #5 of 19 (permalink) Old Jul 26th, 17, 8:43 AM Thread Starter
Correct
post #6 of 19 (permalink) Old Jul 26th, 17, 8:46 AM Thread Starter
Oh I know that. It's open slightly.
post #7 of 19 (permalink) Old Jul 26th, 17, 8:47 AM
steve
did you pull a plug out and check too see if your getting spark?
71'bu is offline
post #8 of 19 (permalink) Old Jul 26th, 17, 9:28 AM
gary
Correct firing order? 18436572.
post #9 of 19 (permalink) Old Jul 26th, 17, 10:57 AM
Hank
Are the wires on the right plugs. Is the wire from the cap to the coil connected. I don't know if you have the linkage that runs from the transmission up to the steering column hooked up but make sure the lever coming out of the column under the MC is all the way up.
HKalin is online now
post #10 of 19 (permalink) Old Jul 26th, 17, 2:41 PM
Did you mess with cap & rotor? Is the rotor in it?
67
70 (SOLD)
Alwhite00 is online now
post #11 of 19 (permalink) Old Jul 26th, 17, 3:11 PM
Bart
Maybe simply knocked the ignition wire loose on the distributor. Define "Not Starting" is it at least cranking over? Don't take this wrong but from the title of your posting and a couple of your comments I am getting the impression you are not very familiar with older engines. The more info you can give us the better we can help you out.
Bart_Swisher is offline
post #12 of 19 (permalink) Old Jul 26th, 17, 6:42 PM Thread Starter
I am getting a spark
post #13 of 19 (permalink) Old Jul 26th, 17, 6:43 PM Thread Starter
It is cranking. Just not firing. I have a spark
post #14 of 19 (permalink) Old Jul 26th, 17, 6:43 PM Thread Starter
I didn't mess with anything other than spark plugs
post #15 of 19 (permalink) Old Jul 26th, 17, 6:44 PM Thread Starter
Yup. All wires going to correct cylinder
This Thread is more than 1110 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
