Click when try to start first try - Chevelle Tech
post #1 of 10 (permalink) Old Jul 26th, 17, 6:41 AM Thread Starter
Thorne
Recently I have been having this problem where I get in and turn the ignition to start it and it just clicks. I have to turn the key back to off then try again then it will start no problem, a few times though it took me two tries to get it going. A starter problem?
71muscle is offline
post #2 of 10 (permalink) Old Jul 26th, 17, 6:51 AM
Keith
Re: Click when try to start first try
Starter solenoid or drive gear. Easy repair once starter is off the car
Maryland Chevelle Club #682
keithb is offline
post #3 of 10 (permalink) Old Jul 26th, 17, 7:05 AM
steve
x2!
71 malibu 6spd 6.0 procharged
2011 streetglide stage 1- sold
05 F350 dually- 602 HP 853 ft lbs torque
former KC-10A Chief-"Our Goal Is Your Hole"
71'bu is offline
post #4 of 10 (permalink) Old Jul 27th, 17, 5:56 AM
Geoff
It could be a number of problems:
[1] ign sw
[2] high resistance in sol wiring
[3] solenoid.
[4] Starter brushes or starter motor problem
Gtogeoff is offline
post #5 of 10 (permalink) Old Jul 27th, 17, 9:42 AM
Jon N.
I'm in with the last choice....
dyno jonn is offline
post #6 of 10 (permalink) Old Jul 27th, 17, 9:13 PM
I say solenoid contact. I had the exact problem you describe. I change the solenoid and all was good.
fcloud is offline
post #7 of 10 (permalink) Old Jul 28th, 17, 7:03 PM
I had this problem on my '69, although more severe than yours...it was the ignition switch. It would just click and sometimes wouldn't engage the starter until the 5th or 6th try.
Busa64 is offline
post #8 of 10 (permalink) Old Jul 28th, 17, 7:13 PM
In addition to the above it could also be corrosion at the battery cable lug to battery post.
oldcutlass is offline
post #9 of 10 (permalink) Old Jul 28th, 17, 8:56 PM
That's not really the symptom of bad brushes.
When brushes are worn it will usually keep "just clicking", not work on the second or third try unless you tap the starter with a hammer to cause the short brush to make contact with the commutator.
post #10 of 10 (permalink) Old Jul 28th, 17, 9:37 PM
Jon N.
I also found that jumping with another car or a hot battery would usually help when the brushes were really worn down. After a while, it did become necessary to actually replace the brushes or the whole starter to cure the problem. I just hated putting money in a car I was planning on selling anyway. Just typical used car salesman mentality I guess.
This Thread is more than 1078 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
