Cam info - Chevelle Tech
  • 1 Post By WOODY367
post #1 of 15 (permalink) Old Apr 8th, 17, 11:53 PM Thread Starter
Cam info
Is there anyway to tell what brand, spec/info of cam is in a engine without removing or taking apart the top end of the engine? The engine was built a few years back and all the paperwork on it is lost.
WOODY367 is offline
post #2 of 15 (permalink) Old Apr 9th, 17, 2:12 AM
Geoff Swanson
Re: Cam info
You could put a drop gauge on the rocker tip and roll the motor over with a crank socket and find out the lift of the exhaust and intake valves, but this will only work on a solid cam motor as a hydraulic cam will bleed the lifter down and not give you a true reading. You could then take that to the manufacturers web page and get a good idea what it is. This is assuming you know who is the manufacturer and if it is a solid cam and roller or flat tappet.
You could also get a good idea using a degree wheel and checking valve timing, but that would be pretty involved.
tucson67ss is offline
post #3 of 15 (permalink) Old Apr 9th, 17, 3:32 AM Thread Starter
Re: Cam info
Not tht I want to do this but if I remove the timing cover and gear would there be info on the front of the cam? Drpping the oil pan would be the big pain.
WOODY367 is offline
post #4 of 15 (permalink) Old Apr 9th, 17, 3:40 AM
Re: Cam info
Is there a specific reason you need to know? Are you unhappy with the performance and plan on changing the cam? If you are happy with the way it runs and are just curious, it might be best just leaving it a mystery.
Steve R
Steve R is online now
post #5 of 15 (permalink) Old Apr 9th, 17, 4:41 AM Thread Starter
Re: Cam info
Was told it was 1 size over stock but seems real lumppy at idle. Als can only time it by ear as it would be soo far advanced, not sure if its off a tooth.Also would like the spec to pick out a torque converter as I an=m switching from a 4 speed to a th350.
WOODY367 is offline
post #6 of 15 (permalink) Old Apr 9th, 17, 11:05 AM
Re: Cam info
do you have the right pointer on the timing cover?
cuisinartvette is offline
post #7 of 15 (permalink) Old Apr 9th, 17, 11:44 AM Thread Starter
Re: Cam info
Yes and even used a piston stop to make sure.
WOODY367 is offline
post #8 of 15 (permalink) Old Apr 9th, 17, 12:08 PM
Troy
Re: Cam info
You could remove the rockers on #1 cyl and degree the cam. That will tell you everything you need to know.
66 CHEVELLE
senna is online now
post #9 of 15 (permalink) Old Apr 9th, 17, 4:13 PM
Re: Cam info
Pull the timing cover it can be done and reinstalled witout dropping the pan. Or take the intake off use a solid lifter and measure.
Sent from my LG-LS997 using Tapatalk
EFI build thread:
Car Build thread:
71 Built 1972 Chevelle Malibu 136 SS clone as far as I know
Strictly Attitude is offline
post #10 of 15 (permalink) Old Apr 9th, 17, 5:52 PM Thread Starter
Re: Cam info
Would all the info be on the face of the cam right behind the timing gear?
Strictly Attitude likes this.
WOODY367 is offline
post #11 of 15 (permalink) Old Apr 9th, 17, 8:21 PM
Troy
Re: Cam info
Could be on the back of the cam.
66 CHEVELLE
senna is online now
post #12 of 15 (permalink) Old Apr 9th, 17, 9:05 PM
Kevin
Send a message via AIM to kev70ss
When I went through the same thing the info was on the back of the cam. Might depend on the brand though
kev70ss is offline
post #13 of 15 (permalink) Old Apr 13th, 17, 1:54 PM
Re: Cam info
It is easier to pull the intake and valve covers in my book then measure the lift
EFI build thread:
Car Build thread:
post #14 of 15 (permalink) Old Apr 16th, 17, 2:18 AM
Rod
Re: Cam info
x2
Rmchevelle is offline
post #15 of 15 (permalink) Old Apr 16th, 17, 2:39 AM
Re: Cam info
Let me see if understand the situation: you can't time the motor, haven't tried seating the distributor correctly one tooth in either direction....but you want to pull the timing cover off to see what cam is in there?
Always start with the simple stuff first. If you can't time the motor, it's likely you are a tooth off. Fix that FIRST.
Good luck!
blue_69_malibu is offline
This Thread is more than 1176 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
