Q jet spits out fuel and smoke on cold starts - Page 2 - Chevelle Tech
post #16 of 37 (permalink) Old Nov 20th, 16, 12:14 PM
Eugene
Re: Q jet spits out fuel and smoke on cold starts
Have you looked inside?
Bonkerman is offline
post #17 of 37 (permalink) Old Nov 20th, 16, 12:18 PM
gary
If you just replaced your plug wires, recheck the firing order. Chevy is 1-8-4-3-6-5-7-2
post #18 of 37 (permalink) Old Nov 20th, 16, 12:33 PM Thread Starter
stan
I checked the distributor rechecked the firing order it all checked fine.
I'm going to check the valve timing. By pulling the valve cover and dist cap. To see if the valves close when piston is up at the. Compression stroke. I'm suspecting the timing chain is worn.
69355 is offline
post #19 of 37 (permalink) Old Nov 20th, 16, 12:45 PM
& Administrator
Block/wire the choke wide open and see if it'll start.
Might take a few trys to clear out the excess fuel.
Check for a sticking needle/seat.
Also, some of the QJ's had an issue with the floats filling/absorbing fuel and sinking causing a flooding situation.
Mike is offline
post #20 of 37 (permalink) Old Nov 20th, 16, 12:48 PM
Eugene
How many miles on the engine?
post #21 of 37 (permalink) Old Nov 20th, 16, 12:52 PM Thread Starter
stan
Must be over 50k not sure exactly.
69355 is offline
post #22 of 37 (permalink) Old Nov 20th, 16, 12:57 PM
Eugene
Probably not a timing chain issue but you can check and see how much slack is in the chain with the dist cap off. Your problem sounds more like badly flooded or ignition issues.
post #23 of 37 (permalink) Old Nov 20th, 16, 1:20 PM
Derrick
Originally Posted by 69355 View Post
Sounds like it is flooded, I built the car but still new to q jet 1708 carbs.
qjet 1708?
-Hank Hill
novaderrik is offline
post #24 of 37 (permalink) Old Nov 20th, 16, 1:24 PM Thread Starter
stan
qjet 1708?
Yes
69355 is offline
post #25 of 37 (permalink) Old Nov 20th, 16, 1:56 PM
& Administrator
This should explain it as he's only giving the first 4 digits (1980's carb)
Mike is offline
post #26 of 37 (permalink) Old Nov 20th, 16, 2:07 PM Thread Starter
stan
I coped this off the carb: 17080212. 1053. CPW
69355 is offline
post #27 of 37 (permalink) Old Nov 21st, 16, 3:15 AM
RANDY
Timing chains mostly fail at start up.
Quick check is to put your timing pointer at zero and the rotor should be pointing at the #1 or # 6 plug terminal on the distributor cap.
Randy
GLHS60 is offline
post #28 of 37 (permalink) Old Nov 21st, 16, 7:48 AM
& Administrator
FYI ,17080212 was from a 80-84 Chev & GMC Truck/Mtr Home 454
Your's appears to be a 1983
Mike is offline
post #29 of 37 (permalink) Old Nov 21st, 16, 9:31 AM Thread Starter
stan
I pulled the engine from a motor home. Thank you
69355 is offline
post #30 of 37 (permalink) Old Nov 22nd, 16, 11:41 AM Thread Starter
stan
Quick update,I got the car started runs very rough, stalls and Alot of backfire out the exhaust. Some fuel spitting out the carbon. I pulled # 1 and #3 spark plug and smells like fuel.
69355 is offline
This Thread is more than 1220 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
