Holley Carbs gas oder after running - Page 2 - Chevelle Tech
 7Likes
post #16 of 21 (permalink) Old Oct 14th, 16, 12:06 AM
Ross
Re: Holley Carbs gas oder after running
Originally Posted by Gtogeoff View Post
Sorry, many countries call what you call a flashlight, a torch.
We need a translation book sometimes lol
old hoon is offline
post #17 of 21 (permalink) Old Oct 14th, 16, 8:42 AM
AKA Zombietroll
Then what's what we call a torch called?
zombie1969 is offline
post #18 of 21 (permalink) Old Oct 14th, 16, 1:52 PM
"Fun" - until someone loses an eye. Then it's "Hilarious".
lucifershammer is online now
post #19 of 21 (permalink) Old Oct 15th, 16, 1:08 PM
Originally Posted by chevyfan61 View Post
Why does my carb seem to leak gas after a drive? When I get out of the car there is a really strong oder of gas. I can't find any leaks anywhere. It seems like the carb is leaking down after it stops running
If this is under the hood, it is possible that the accelerator pump arms could be adjusted a hair too tight. Some small amount of fuel could be getting drawn into the throttle bores even at idle. Throttle bores could be a little wet, so residual stink after you shut it off. A small leak around the accelerator pump diaphragm gasket could stink up the place too.
If it is outside the car, venting from gas cap can stink a little.
Also old muscle cars stink in general if you get your nose too close. It aint no Prius.
My old car is fuel injected without a fuel leak anywhere, but I can still smell fuel in the throttle bores with an open air filter element if I get close enough. Just saying.
'65 Chev El Camino
SBC350/Maybe 400HP @ crank, 700R4
Edelbrock Pro-Flo 4 4150 MPFI
'67 P-11 Norton
Schwany is offline
post #20 of 21 (permalink) Old Oct 15th, 16, 5:50 PM
Geoff
Zombie,
If I am reading your question correctly, what you guys call a 'torch', we call a propane or oxy/acet torch.
Gtogeoff is offline
post #21 of 21 (permalink) Old Oct 15th, 16, 8:52 PM
rkd
Ron
I did not see the carb number listed, but I have had a couple of older 4160s that would leak from the secondary bowl through the gasket behind the secondary metering plate and drip into the secondary bores. First sign was a slow idle, sometimes with black smoke.
Pulling the rear bowl and tightening the clutch head screws on the metering plate would fix it for a couple weeks, then it need a new gasket.
rkd is offline
This Thread is more than 1363 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
