PCV Valve Fouling my plugs and Bad Idle Quality - Page 6 - Chevelle Tech
 13Likes
post #76 of 91 (permalink) Old Aug 24th, 16, 10:04 PM
Re: PCV Valve Fouling my plugs and Bad Idle Quality
Does it matter if I run both a breather and a PCV towards the front of the engine on opposite sides?[/QUOTE]
No
Aaron is offline
post #77 of 91 (permalink) Old Aug 24th, 16, 10:07 PM
Jack
Originally Posted by SHINER View Post
I ordered the fancy PCV valve and a catch can.
That's where we are headed with GDI cars.
boyd66k20 likes this.
Importtech is offline
post #78 of 91 (permalink) Old Aug 24th, 16, 10:21 PM
Cant hurt. Can only help!
Good luck with the new part!
Aaron is offline
post #79 of 91 (permalink) Old Sep 2nd, 16, 10:40 PM Thread Starter
Travis
So got my ME Wagner installed and working right and a Moroso Catch Can Installed. Car seems to drive better with a PCV. However, trying to tune my radical roller cam with a vacuum gauge is next to impossible.
If I tune by the gauge I end up leaning it out so much it's hard to start the next day.
I chunked the vacuum gauge in the drawer as I'm just chasing my tail with it. I decided to start with the baseline 1.5 turns from seated and try to lean it out as best I could but not affect idle quality. I ended up 1 and 1/16 turn out with a 950 idle. Car seems to like it with a 12.0-12.4 idle AFR and the car sounds better all round. I think I'm gonna just call it done. My engine only makes about 7" of vacuum but I don't have any vacuum dependent equipment and it's enough to suck fuel at idle.
1970 Chevelle
SHINER is offline
post #80 of 91 (permalink) Old Sep 2nd, 16, 11:45 PM
What's your cam? 7" is kinda low.
77 Monte
11.93 @ 112.7 & tuning
77 cruiser is offline
post #81 of 91 (permalink) Old Sep 2nd, 16, 11:47 PM Thread Starter
Travis
Originally Posted by 77 cruiser View Post
what's your cam? 7" is kinda low.
@ 50
233/240 .583/.550 104 icl 108 lsa
1970 Chevelle
SHINER is offline
post #82 of 91 (permalink) Old Sep 3rd, 16, 8:06 AM
How much timing do you have at idle?
77 Monte
post #83 of 91 (permalink) Old Sep 3rd, 16, 9:25 AM Thread Starter
Travis
34* locked out. My distributor is a billet e curve
1970 Chevelle
SHINER is offline
post #84 of 91 (permalink) Old Sep 3rd, 16, 10:15 AM Thread Starter
Travis
Is too much idle at start up and cruising around town going to make it harder to start and sluggish? My SCR is 10.3 and DCR 8.11
fr8dog likes this.
1970 Chevelle
SHINER is offline
post #85 of 91 (permalink) Old Sep 4th, 16, 7:35 AM
Geoff
If your starter has enough HP, it will crank fine. HP ratings ranger from about 1.2 to 3.4 HP for top of the line starters like the MSD Dyna Force. Some starter companies provide useless tq ratings instead of the rated HP of the starter to try & fool you.
Gtogeoff is offline
post #86 of 91 (permalink) Old Sep 4th, 16, 9:33 AM Thread Starter
Travis
I have a CVR Mini Starter. My question is should I have an advance curve? I drive this car 100% on the street for fun. I notice it has a miss all the time putting around down low. I'm currently locked out at 34* at all times
1970 Chevelle
SHINER is offline
post #87 of 91 (permalink) Old Sep 4th, 16, 2:11 PM
Seems to me a motor would run better on the street with a proper advance curve. All my experiments with forcing the advance in early only worked when I floored the car. Real bad cruising manners stop light to stop light on the street if all in by 2000rpm. Every motor is different though. Good luck
'65 Chev El Camino
350/400+HP, 700R4
Edelbrock Pro-Flo 4 MPFI
'68 P-11 Norton
Schwany is offline
post #88 of 91 (permalink) Old Sep 5th, 16, 10:34 PM
I would recommend a vacuum advance distributor for better drive-ability. Locked out distributors are great for strip only cars but suffer on the part throttle cruise. You can get it running and enjoy it for a while and upgrade later.
1969 SS396 Convertible
Bob Tiley is offline
post #89 of 91 (permalink) Old Sep 6th, 16, 6:16 AM
Geoff
Having additional cruise timing via vac adv would be a good idea.
However, current timing locked at 34* is adequate & would not be causing low speed misfire; most likely cause is leanness.
If you have a choke, try this: engine idling, close choke blade until engine note changes. Lock the choke blade in this position with some tie wire. Test drive car. If misfire is improved/gone, you are too lean on cruise.
Note: the fix is not increasing main jets/PV. The fix is to richen the idle cct because low speed cruise is on the idle cct via transfer slots.
Gtogeoff is offline
post #90 of 91 (permalink) Old Feb 7th, 17, 8:24 PM Thread Starter
Travis
Contact ME Wagner. mewagner.com. Get a real PCV valve and employ a catch can. That's what I now recommend ppl. Has helped me alot
fr8dog likes this.
1970 Chevelle
SHINER is offline
This Thread is more than 751 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
