SBC Stepped Nose Cam in Early Block? - Page 3 - Chevelle Tech
 9Likes
post #31 of 34 (permalink) Old Jul 30th, 16, 9:33 PM
Re: SBC Stepped Nose Cam in Early Block?
Gary, as I'm sure you're aware a traditional SBC cam sprocket is sort of a press fit on the cam and the dowel pin is a tight fit. in this type deal the 3 bolts really don't serve any locating function at all, just keep the sprocket from falling off.
I've always wondered how this works on a step nose deal.
post #32 of 34 (permalink) Old Mar 1st, 17, 9:42 PM
Gary, what is the plate, mild steel or is it hardened?
77 Monte
11.93 @ 112.7 & tuning
77 cruiser is offline
post #33 of 34 (permalink) Old Mar 3rd, 17, 12:30 AM
I think he's using the factory plate, it's hardened.
post #34 of 34 (permalink) Old May 1st, 17, 8:46 AM Thread Starter
Time now to make an addition here.
We've been able to put together about 12 installation kits to get the thrust plates mounted in placed, 1/2 are full kits with ALL the tooling and the other 1/2 are partial's.
The full kits have a modified pre-drilled thrust plate, attaching screws, locating fixture, clamping tool, correct drill bit, 3-pc tap set, and correct countersink.
Partial kits have no tooling included.
I have a one or two set up's to do the Dart "Little-M" blocks also. This casting uses a different size front cam bore hole than the OEM castings.
Thanks, Gary in N.Y.
P.S. For anyone interested in the details/pricing please contact me with an e-mail (preferable) if possible.
Can get me at: [email protected]
Sept. 2019 Drag-Week Winner - N.Y. Legal Streeter - 1956 Chevy Bel-Air 7.23 @ 196+ @ 3800#
Best time to date-11/2019 7.00 @ 204+ @ 3800#
GOSFAST is online now
This Thread is more than 986 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
