396 timing chain covers and oil pans - Chevelle Tech
  • 1 Post By 1966_L78
post #1 of 7 (permalink) Old Jun 1st, 16, 8:09 PM Thread Starter
Paul
My El Camino came with a 396 thrown in with the deal. The oil pan on that motor would not clear the cross member. Ordered a pan from Summit. Motor now fits fine. The new pan has a bolt hole in the center of its lip below the balancer but there's nothing for it to thread into. Since the original pan didn't fit I'm wondering if there were also different configurations of timing covers, say what worked for a truck would not work in a passenger car?
Paul J
'69 El Camino SS
396 CI,Hooker Super Comps
TH400, HEI, Performer Intake, 750 cfm
Paul J is offline
post #2 of 7 (permalink) Old Jun 1st, 16, 8:21 PM
Mr Bill
Re: 396 timing chain covers and oil pans
Cant say that I have ever seen that. Picture ?
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
Team Chevelle #100
BillK is offline
post #3 of 7 (permalink) Old Jun 1st, 16, 9:30 PM
p40
butch
im thinking the early 66 67 oil pan had hole in the front lip , i bought a new pan for my 427 it had the hole i brazed it shut so no oil leaks
p40 is offline
post #4 of 7 (permalink) Old Jun 1st, 16, 10:11 PM
I've seen lower seals with a nipple to pull thru the hole. Seals it, keeps it centered, not sure. My BB oil pan has the hole, and with the one piece Fel Pro gasket, it does not leak.
"SSuper Dave" Palmer
A.C.E.S. #1483 TC #32 Gold
SSuper Dave is offline
post #5 of 7 (permalink) Old Jun 2nd, 16, 2:52 AM
The '65 ( and '66) 396 had a bolt in that position, that threaded into the timing cover. But I have also seen the gasket nipple...
Chevelle Oil Pans
Generally, timing covers should functionally interchange, as long as the correct diameter balancer is used (7" or 8")... The timing marks may need to be checked/verified (should be the same, but I recall someone telling once that some were off)...
65 and 66 timing covers had no dowel pin holes. Not sure when they changed, but later blocks used the dowels... But otherwise they should interchange...
CDN SS likes this.
TC #1366
Sold
Sold
1966_L78 is offline
post #6 of 7 (permalink) Old Jun 2nd, 16, 7:00 AM Thread Starter
Paul
the cover has dowel pins. this is a bolt hole but does have holes for gasket nipples. think i'll just fill the hole in as someone else suggested. thanks all.
Paul J
'69 El Camino SS
Paul J is offline
post #7 of 7 (permalink) Old Jun 2nd, 16, 9:08 AM
David
My 67 396 SS uses the bolt behind ballencer to mount the timing cover.
55 210 Chevrolet New project
64 El Camino (sold to finance new project)
67 SS Chevelle '396
69 Sanger Flat Bottom boat
77 El Camino parked daily driver
78 Z/28 Camaro, High School Car Class of 80 350'
80 Spectra 21' Mini Day cruiser Blown 454
88 IROC Camaro (sold to finance new project)
1994 fac2 dr Blazer 4x4
02 F-250 7.3L Diesel 4" lift
david_396 is offline
This Thread is more than 1462 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
