781 porting - Chevelle Tech
post #1 of 14 (permalink) Old Feb 2nd, 16, 8:26 PM Thread Starter
781 porting
Any key areas to get back into?
I'm going to have them cut for 2.25/1.88.
I have toyed with the idea of just jumping to 2.19 and leave the hot side stock with good valves and seat job.
A little input would be good. I've been reading up on these for a while. Intake and exhaust have been cleared of any casting flashes or boss bumps ( i got into the threads for the rocker stud on two ports per head)
Sorry if this is jumbled... I've been drinking
87chevy is offline
post #2 of 14 (permalink) Old Feb 2nd, 16, 8:50 PM
BTK
billy the kid..
Re: 781 porting
Wow!! ...a little liquid courage for your first post???..welcome to the forum show!!!!
BTK is offline
post #3 of 14 (permalink) Old Feb 3rd, 16, 7:20 AM Thread Starter
Just a little, and thanks. I have been lurking in Chevelles.com for a long time.
I'm wanting to take them in to get cut soon but would like to only have to bowl blend when they come back. I'm wondering if some folks are going to chime in with any area that will gain flow that needs to be addressed.
87chevy is offline
post #4 of 14 (permalink) Old Feb 3rd, 16, 7:24 AM Thread Starter
Only other picture I have on my phone
ID:	329690   Click image for larger version
ID:	329698   Click image for larger version
87chevy is offline
post #5 of 14 (permalink) Old Feb 3rd, 16, 7:55 AM
Spike
Re: 781 porting
Not bad for a first post.
From what I have observed,
we don't need to have the razor thin
ridge on the exhaust. Look around and
read you'll find that most recent heads
are rounded off in this area.
Other folks here could confirm this.
Cheers,
USMC_Spike
USMC_Spike is offline
post #6 of 14 (permalink) Old Feb 3rd, 16, 9:26 AM
Re: 781 porting
What size bore is it going on? I would be worried about a 2.25 and chamber shrouding. A 2.19 may actually flow just as well by having more space around it. A 1.88 exhaust valve is pretty big for any engine really. A 2.19/1.72 may not be a bad combo. I was looking at doing that setup on a 408 being used in a drag car. I figured since my 540 uses a 2.35/1.88 setup, a smaller engine shouldn't need such a big exhaust.
Ray
bracketchev1221 is online now
post #7 of 14 (permalink) Old Feb 3rd, 16, 9:34 AM
Rich
Re: 781 porting
We did 2.19/1.88 on my 049 heads used on the 427. No work in the combustion chamber but complete work in the ports per recommendation of the guy who did the porting (who is also a Pro Comp drag racer). They work VERY well.
NCOA member #220
ACES member #1670
Team Chevelle #998
Rich Cummings
Rich-L79 is offline
post #8 of 14 (permalink) Old Feb 3rd, 16, 12:48 PM
Re: 781 porting
No need for 2.25 valve. I would stick with 2.19 as others have mentioned. I have seen 700+ HP 496 pump gas motors with 2.19 valves w/GM heads.
mr 4 speed is offline
post #9 of 14 (permalink) Old Feb 3rd, 16, 1:24 PM
Gerry
Re: 781 porting
X2 on that. This link has some good pointers.
Do-It-Yourself Small-Block Cylinder Head Porting - Tech Article - Chevy High Performance Magazine
67 SS BBC
4.11's
bradley67 is offline
post #10 of 14 (permalink) Old Feb 3rd, 16, 1:48 PM
Re: 781 porting
Couple of questions:
Did the guy have any feedback on the typical practice of cleaning up the chamber surface with a spiral roll? I see it's as-cast here.
Did he take material out of the walls/roof/floor, or just transition/blend?
Stu1 is offline
post #11 of 14 (permalink) Old Feb 3rd, 16, 3:26 PM
Rich
Re: 781 porting
We were trying to maintain the combustion chambers as small as possible to keep compression and dynamic compression ratios up. He said he didn't see any advantage to smoothing out the combustion chamber surfaces for what I was trying to accomplish.
He took out material to open up the throats, smooth the transitions and increase the flow. He has a flow bench and he has worked heads like this many, many times. He removes what helps flow not to simply increase the size of the ports. I honestly don't know the particulars of what he does or doesn't manipulate. According to his flow bench they all flow quite well for what they are.
For example, the intake ports were measured to flow about 307 cfm at .600 lift. .
NCOA member #220
ACES member #1670
Team Chevelle #998
Rich Cummings
Rich-L79 is offline
post #12 of 14 (permalink) Old Feb 3rd, 16, 4:15 PM
Re: 781 porting
On this platform, the OEM CI "oval's", I would use some 2.125" or 2.150" x 5.250" SBC intake valves and some 1.810" x 5.370" Mopar exhaust's. We use this setup all the time on the 100% stock-appearing builds.
If you use theses sizes AND do a decent port job the heads WILL deliver.
Have 3 sets being done this week, most get Ferrea's valves. Fairly straight-forward operation. Occasionally we'll use Manley's intakes also.
(Add) With respect to porting on the exhaust's, I would stay away from the bottoms of those guides, this is a "high-stressed" area where the guides are pressed in and very close to water!! Just a tip.
Thanks, Gary in N.Y.
P.S. The lengths work well and all have SBC .343" stem diameters.
Sept. 2019 Drag-Week Winner - N.Y. Legal Streeter - 1956 Chevy Bel-Air 7.23 @ 196+ @ 3800#
Best time to date-11/2019 7.00 @ 204+ @ 3800#
GOSFAST is offline
post #13 of 14 (permalink) Old Feb 3rd, 16, 9:54 PM
MARK
Re: 781 porting
Great advice!
Machined GM production heads
Oil pan modifications
VORTECPRO is offline
post #14 of 14 (permalink) Old Feb 4th, 16, 11:38 AM
Rich
Re: 781 porting
Originally Posted by VORTECPRO View Post
Great advice!
So why not just use off the shelf 2.19/1.88 BBC valves with 11/32" stems? Seems like they'd be easier to find (and maybe less expensive?) and provide roughly the same valve size.
NCOA member #220
ACES member #1670
Team Chevelle #998
Rich Cummings
Rich-L79 is offline
This Thread is more than 1484 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
