Doh! rod pressed on backwards... - Chevelle Tech
  • 1 Post By 1966_L78
post #1 of 8 (permalink) Old Jan 22nd, 16, 12:27 AM Thread Starter
I needed a new rod for my Buick 340, so I went to a local shop. They got me a "remanufactured" rod and pressed on my old piston...
Got home, and it didn't look right... Put a bearing shell in, and it was all the way to the edge (hit the crank "radius"?... Turned the piston upside down, and it slides right onto the crankpin...
Turned it back the correct way, and no go...
Went on-line, and found old Service manuals, and sure enough, there are some "bosses" cast into the rod and cap... The orientation is backwards...
Just hope they don't try to blame it on me, and I hope they can R&R on the spot, as the shop is kind of out-of-the-way...
So now I have to go bad to the shop and have them correct their error...
TC #1366
Sold
Sold
1966_L78 is offline
post #2 of 8 (permalink) Old Jan 22nd, 16, 9:42 AM
Re: Doh! rod pressed on backwards...
That sucks. I had that happen to me once. Reputable shop that was 1 1/2 hr. away did the same thing. They wouldn't swap it around while I waited, so I had to make 2 trips, = 6 hrs. driving. Haven't been back since.
nitrofox is offline
post #3 of 8 (permalink) Old Jan 22nd, 16, 1:35 PM Thread Starter
The shop swapped it while I waiting this morning. They even apologized... They also explained that the rod was a slightly different casting...
hopefully back on track now...
airrj likes this.
TC #1366
Sold
Sold
1966_L78 is offline
post #4 of 8 (permalink) Old Jan 23rd, 16, 6:48 AM
Jesse
Had that happen once on a sbc I had balanced at a reputable performance shop. I just bought a set of heads that they just did and 3 of the guides need replaced. Won't be going back.
6426yy is offline
post #5 of 8 (permalink) Old Jan 23rd, 16, 2:58 PM
Happens surprisingly often with Pontiac engines. #2 on a Pontiac is the furthest-forward rod, with #1 behind it. So too often, folks mis-number the rods, and too often, the shop doesn't understand which way the chamfer has to face to match the crankshaft.
Schurkey is offline
post #6 of 8 (permalink) Old Jan 24th, 16, 10:42 AM
Rob
I can't decide if the rod is pressed on backwards or if the piston is pressed on backwards. Another good thing about floating piston pins I guess, you can just remove the clips and turn the piston around.
My build thread>
65chevelle300post is offline
post #7 of 8 (permalink) Old Jan 24th, 16, 12:58 PM
Please explain the difference.
Schurkey is offline
post #8 of 8 (permalink) Old Jan 24th, 16, 2:47 PM
Rich
Hate to see this...many times the metal will gall in various places when heated and pressed again.
Rich
1967 El Camino (White)
1965 El Camino (Sold that junk)
HandOverFist is offline
This Thread is more than 1589 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
