#3 Exhaust hotter by 130* ????? - Chevelle Tech
post #1 of 4 (permalink) Old Dec 4th, 14, 1:25 PM Thread Starter
Cory
427 BBC fresh build solid roller
During 20-30 minute break-in of fresh build my infra red thermo measured #3 exhaust port at the header 130* hotter than others.
After break-in I readjusted the valves and on restart same differential on #3
Any ideas why??????
Cause for concern????
dream66 is online now
post #2 of 4 (permalink) Old Dec 4th, 14, 1:43 PM
Re: #3 Exhaust hotter by 130* ?????
Had a similar experience on a fresh-fired 496, except it was #8 running hotter than the others (about that same amount). It was being caused by a leak at the vacuum distribution fitting on the intake manifold. Dumb oversight on my part, I had hooked up all the lines except the one to the Cowl Induction diaphragm (hood was not yet on the car)
That cylinder may be running lean, I would check all vacuum sources and if that's all good it might possibly be leaking at the manifold sealing surface at that port.
1971 Chevelle SS LS5 Lime Green/ Jade
496 TH400 4.10 rear
Track times pending
1987 Buick Grand National
11.60 ET 88K stock long block with bolt-ons
TX71SS is offline
post #3 of 4 (permalink) Old Dec 4th, 14, 3:00 PM Thread Starter
Cory
Originally Posted by TX71SS View Post
...it might possibly be leaking at the manifold sealing surface at that port.
Well, of course...that would do it. Duh !!!!
Thanks a bunch
post #4 of 4 (permalink) Old Dec 4th, 14, 5:13 PM
You're welcome...but I hope it's something easier than that to fix. Good luck and let us know what you find.
496 TH400 4.10 rear
Track times pending
TX71SS is offline
This Thread is more than 1880 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
