Valve Covers & gaskets - Chevelle Tech
post #1 of 7 (permalink) Old Oct 10th, 14, 4:37 PM Thread Starter
Bought a set of Stock looking tall valve covers and Summit Racing Valve cover gaskets with Rubber / steel core
- What's the best way to install them without them leaking, should I glue the gaskets to covers? if so what sealant do I use?
1967 Chevelle Oshawa Built Car
-427 .60 over, Lunati 60211 Roller cam
-Super T10 2.64
-Dana 60 3.54 Posi
1967 chevelle is offline
post #2 of 7 (permalink) Old Oct 10th, 14, 5:15 PM
Guy
Re: Valve Covers & gaskets
I have been using a set of Felpro rubber/steel core gaskets for several years and I do not glue them to anything.
Guy
'86 Monte SS,
513 Stroker,
AFR CNC'd 315 heads,
Isky .904 EZX Roll lifters,
9 inch rearend,
TC Member # 4921
GuysMonteSS is offline
post #3 of 7 (permalink) Old Oct 10th, 14, 5:51 PM
Rocky Hill
Throw the rubber gaskets away and get cork. I put a thin layer of grease on my fingers and lightly coat the cork gasket, and NEVER NEVER have I ever had a leak. The key is not to over tighten the valve cover bolts.
Rocky
A Man And His Chevelle!
It's A Beautiful Thing.
TC Member #1530
Mid America Chevelle Club
Queen City Chevelle Club
Heartland Chevelle Club
My Showroom
rocks66ss is offline
post #4 of 7 (permalink) Old Oct 10th, 14, 6:40 PM
Freddy
Rocky
Don't over tighten!!!! Resist the urge!
Freddy Mercado is offline
post #5 of 7 (permalink) Old Oct 11th, 14, 1:55 AM
Marcus
I have the summit gaskets. I installed them dry.
Marcus
Chevelle Malibu ss 64
Th 400 Edge 9.5" converter
Malibu ss 64 is offline
post #6 of 7 (permalink) Old Oct 11th, 14, 3:00 AM
Derrick
install them dry. using studs instead of bolts to make it easier to line up..
of they leak, see if Fel Pro makes cork gaskets with a steel core and crush limiting sleeves like they do for the small blocks.. i had a set of those on my Monte for several years and they never leaked even after having the covers off at least a dozen times..
-Hank Hill
novaderrik is offline
post #7 of 7 (permalink) Old Oct 12th, 14, 2:26 AM
Squido(skee-doe
Whatever type of gasket you decide to use, just snug them down evenly. If they leak a little then you can try a little tighter. Leaking is usually from tighting them too much and you can't go back once you compressed the gasket too much. As for the studs.... I think they work OK on aluminum valve covers, but, the sheet metal valve covers seem to get stuck on the threads of the studs.
Just one mans opinion.
Squido
Squido W Cash
Experienced
So. Calif. Mickey and Donalds home town
in progress
68 Malibu 454, th400, 12 bolt 411 MegaSquirt
79 350 Vette
80 350 Vette
70 F**d 250 pick-up
31 Model "A" Grocery Getter
73 El Camino soon to be big block
Experience varies directly with equipment ruined.
swcash is offline
This Thread is more than 1712 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
