Sbc to bbc conversion kit - Chevelle Tech
post #1 of 7 (permalink) Old Sep 22nd, 13, 7:37 PM Thread Starter
These kits any good? I have the frame mounts still in my car but it had a sbc in it...just looking for what I need to get to drop the motor in when it's time...any tips on this kits or what others have done?
http://www.ss396.com/mm5/merchant.mv...ode=AMC-103KIT
19chevelle66 is offline
post #2 of 7 (permalink) Old Sep 22nd, 13, 8:07 PM
jackie
Re: Sbc to bbc conversion kit
When I put the Rat in my 67 Malibu, all I did was set it right down on the existing perches in conjunction with regular big block motor mounts.
It was originally a 283 car with a powerglide.
jackie schmidt is online now
post #3 of 7 (permalink) Old Sep 22nd, 13, 8:18 PM
Todd
what is actually different in a bb car mounts vs a sb car?
72 Chevelle
70 Nova 540 ,powerglide SOLD
67 El Camino
Tod74 is offline
post #4 of 7 (permalink) Old Sep 23rd, 13, 4:22 AM
Marcus
Several threads about this, you can use both sb or BB frame mounts in a 64-67 doesnt matter as long as you use the matching motor mounts. BB frame mounts can take a interlocking motor mount that wont fit a sb frame mount.
Heres a thread with pics that shows the difference.
https://www.chevelles.com/forums/showthread.php?t=174732
Good luck with the BB install!
Marcus
Chevelle Malibu ss 64
Th 400 Edge 9.5" converter
Malibu ss 64 is offline
post #5 of 7 (permalink) Old Sep 23rd, 13, 8:38 AM Thread Starter
My sbc are still in place so if the big block still has the motor mounts on it im set?
post #6 of 7 (permalink) Old Sep 23rd, 13, 1:04 PM
Or, if you use the Energy Suspension "short and wide" motor mounts, those will fit either frame mount and handle all the HP you want to throw at them for street cars. I have those in my 65/496, my buddies 66/502 and my Son's 68/454. All with the original SBC frame mounts. The official SBC frame mounts have an interference with the original interlocking BBC motor mounts hitting the frame mounts before the bolt hole aligns properly. FWIW, Ed
*Harley - 06 Street Bob
*Peach State Chevelle Member
*Retired June 1, 2014****
OLDED is offline
post #7 of 7 (permalink) Old Sep 23rd, 13, 1:16 PM
Marcus
Use the mounts from the sb engine if the BB has 64-67 Chevelle BB mounts they are the interlocking style and wont fit the sb frame mounts. I like one solid moroso mount on driver side and oem rubber on passenger side if you have lots of hp.
Marcus
This Thread is more than 2309 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
