#1 Plug is Fouling. - Chevelle Tech
post #1 of 9 (permalink) Old Jul 31st, 13, 10:45 AM Thread Starter
Rocky Hill
#1 Plug is Fouling.
I haven't done any diagnoses yet thought I would get some of you're ideas first.
Ignition is Pertronix III with the Flamethrower HC coil 60k volt. I run AC R44xls plugs gapped at .040, MSD 8mm street fire wires, and my pcv is ran to the front port on my Holley 670SA.
It is only on the number one plug. It is light fluffy black soot that's on the on the plug.
I just replaced my valve seals a couple of weeks ago, and I took my plugs and cleaned them with a steel brush on my bench grinder, cleaned out the cavity with carb cleaner, regapped them and put them back in.
Suggestions, ideas?
Rocky
A Man And His Chevelle!
It's A Beautiful Thing.
TC Member #1530
rocks66ss is offline
post #2 of 9 (permalink) Old Jul 31st, 13, 4:46 PM
Tim
Re: #1 Plug is Fouling.
rotate plug to another cylinder to see if plug or another problem. could be intake gasket to head ,oil being drawn in. or piston rings, I would try a leak -down test also.
mrchevyl88 is offline
post #3 of 9 (permalink) Old Jul 31st, 13, 5:18 PM
Keith
Valve seal replacement means you did a relash of valves, right? Solids or Hydraulic cam? Incorrect valve lash, especially borderline too-tight, can lead to intermittent dead cylinder issues.
Keith
Owner: World's Fastest 66 Chevelle - really...it's really really fast since I put on that chrome differential cover
CoolBlueGlow is offline
post #4 of 9 (permalink) Old Jul 31st, 13, 5:52 PM
Ken
As stated plus rotate plug wire to another cylinder.
Inspect cap for bad terminal on one.
If basic stuff doesn't work, compression check and or leak down.
Do you feel a miss, how soon does plug foul.
Good Luck.
Bluegoose1970 is offline
post #5 of 9 (permalink) Old Jul 31st, 13, 9:38 PM Thread Starter
Rocky Hill
There is no miss. It's just light fluffy black soot on the one plug.Looking at a plug chart in a chiltons, it looks like what they say is carbon deposit.
As far as lash goes, I set them running, a good strong 1/2-5/8 turn past zero lash. I will try rotating plugs, and then change wires to another and see what happens. I was wondering if maybe the heat range on the plugs were one off.
Rocky
TC Member #1530
post #6 of 9 (permalink) Old Aug 1st, 13, 1:24 AM
Ken
Glad to see the running valve lash set. If anything, as you do it, it's right and you can tell if you have valve train problems.
Sounds like you have it under controlled.
Either you have lack of spark problem, or lack of compression, and of course plug fowling by contamination. One cylinder, tends to rule out fuel delivery, unless you have other rich cylinders. What do the other plugs look like? how do you drive the car. You could be running rich and #1 is affected more than the others. After all you do have leaner and richer cylinders.
Heat range may help, what heads do you have, but why only one cylinder affected? How old are the plugs? Install new plugs, take the car out and run it, try to find a place where when you do it, you can shut it down without stopping or idling the least amount. Remove the plugs and read them.
Check your pcv hose, if your getting excessive oil in it, you may be drafting oil to this cylinder more than others, depending on your intake, and fowling the plug. Move it to the rear or manifold vacuum tee or plug it to test. You can clean or replace it, make sure it is the correct one for your manifold vacuum.
Also cleaning plugs with a steel brush, let alone mounted on a bench grinder is not good. Your burnishing the porcelain, which may lead to cracking, but you are impregnating steel in the porcelain causing it to become conductive leading to misfiring. Same reason you do not use steel brushes when welding aluminum, you can see the contamination in the aluminum. If you have to clean plugs, nylon brush and chemical cleaner. If they don't clean easy, buy new plugs. I used to have a 1940 plug sandblaster, don't think that's done anymore.
Be looking forward to your problem being resolved. Good Luck.
post #7 of 9 (permalink) Old Aug 1st, 13, 1:44 AM
Frank Riley
Rocky, It certainly wouldn't hurt to try an R45 heat range plug to see if that might help. I run R45TS (or equivalent) plugs exclusively in all my cars (for nearly all city stop n go driving...)
70-454 LS5
Greater Kansas City
70-SS454 is offline
post #8 of 9 (permalink) Old Aug 1st, 13, 1:03 PM Thread Starter
Rocky Hill
Well Ken I never gave a thought about the fact I may have put metal into the surface of the porcelain tip. I swapped the #1 plug after wiping it off with a cloth with #3 and see it that makes a difference. #3 looks normal. If not I will check distributor cap and change out a wire as I have another set of wires hanging in the garage.
And Frank, You have a pretty good idea what kind of driving I do, mostly stop and go in the city. I had wondered for some time if I shouldn't go to R45 plugs anyway.
We will see what my changes do.
Rocky
TC Member #1530
post #9 of 9 (permalink) Old Aug 1st, 13, 1:22 PM
Ken
X2
Good clean running for stop and go.
This Thread is more than 2371 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
