>0.450 lift with stock heads - Chevelle Tech
post #1 of 8 (permalink) Old Jan 8th, 11, 8:19 PM Thread Starter
Mike Mowl
I was in a recent bench racing session and got the advice not to go over 0.450 lift with stock heads when selecting a cam. I have heard several different warnings about over camming an otherwise mild engine but never this one.
My question is why would the heads matter if the valve springs were strong enough? After market heads have only come into reach for the average shade tree builder in the last few years. Stock castings were what was used for years whether you used a mild or aggresive cam.
Did I misunderstand?
Mikeylikesit is offline
post #2 of 8 (permalink) Old Jan 8th, 11, 8:41 PM
"Wild Bill"
Re: >0.450 lift with stock heads
I would guess the valve lift limitation was referring specifically to the factory valve train (springs) on a stock head.
1967 Camaro SS-Gen I
2017 Camaro RS-Gen VI
2019 Cadillac XT5 AWD
1990 Ford F150 XLT Lariat
BillsCamino is offline
post #3 of 8 (permalink) Old Jan 8th, 11, 9:02 PM
& Administrator
Also guide to retainer clearance.
Mike is offline
post #4 of 8 (permalink) Old Jan 9th, 11, 9:00 AM
I ran a Crane Fireball years ago in a totally stock 350 except for headers. Specs where 216 @.050 .454 lift 110 LSA
I have also used the [email protected] .480 in a stock 350 that had a carb,intake and headers.
No issues with either.
Keep in mind the factory L46/L82 camshaft was a dual pattern and had .450/.460 lift
so...go back and kick some bench racing ass
mr 4 speed is offline
post #5 of 8 (permalink) Old Jan 9th, 11, 12:19 PM
Banned
Anthony
Years ago I put a Isky 280 mega with .485 lift in a stock 327 with stock power pak heads and had no issues. Wasn`t the smartest thing but it worked. The only time I`ve heard the .450 lift rule as when dealing with vortec heads. You can always just drop on some Z28 springs and be done. They are good to around .500-.510 lift depending on who you talk to.
sschevellefan is offline
post #6 of 8 (permalink) Old Jan 9th, 11, 6:52 PM
In the mid `60's all small blocks got the same springs, including those equipped with the .480 lift 30/30 cam. IMO, .480 was near the limit for the stock springs. Those same springs may not handle that much lift after lots of miles and years. Personally, I would go ahead and get the cam I wanted along with the recommended springs.
Jerry70 is offline
post #7 of 8 (permalink) Old Jan 9th, 11, 9:26 PM
Frank Riley
Study up on "Valve Spring Bind" (also need about .030" clearance for your valve stem seal.)
70-454 LS5
Greater Kansas City
70-SS454 is offline
post #8 of 8 (permalink) Old Jan 10th, 11, 7:44 AM
Ken
Last year I put a l79 type cam in a smogger 350, 224/224 447/447.
It would only rev to 5000 rpm. Then I put some z28 type springs in and it will go to almost 6000rpm.
upstand2 is offline
This Thread is more than 3305 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
