tri power for a bbc? - Page 3 - Chevelle Tech
post #31 of 267 (permalink) Old Jan 9th, 09, 7:31 PM
pdq67
Guest
Posts: n/a
Re: tri power for a bbc?
Sorry,
Too dam high-priced for my blood!
I want a Man-A-Fre Port Induction setup instead!
pdq67
post #32 of 267 (permalink) Old Feb 2nd, 09, 11:07 AM
Fred
Like I said, get three 2300 2 bbls and three front bowls from the 1850 series and you can build your own carbs. Only trick is milling the air horn to a half moon.
Can you go into the details for us?
Also can someone go into the details of swapping the vacuum set-up to a manual linkage?
I also found this post on the Corvette Forum about Tri-power performance compared to a modern single 4 bbl set up.
Corvette Enthusiast did an 11.5:1 489 buildup using AFR 315 CNC heads. (May 2006) They tested 3 induction systems: Holley Strip Dominator 4150; Edelbrock RPM Air Gap and a modified 67 Tripower. The 4-bbl intakes were tested with a Holley 950 HP carburetor. The results were impressive:
RPM Air Gap w/Holley HP 950: 643 HP @ 6400; 594 lb-ft @ 5100
Vic Jr. w/ Holley HP 950: 641 HP @ 6400; 603 lb-ft @ 5100
Tripower: 655 HP @ 6200; 591 lb-ft @ 5100
Full post: http://forums.corvetteforum.com/engi...potential.html
I also emailed Corvette Enthusiast to see if I can get a copy of the article.
Chicken Coupe is offline
post #33 of 267 (permalink) Old Feb 2nd, 09, 12:28 PM
I recall typing up a detailed blueprint and posting it here soemwhere, but it was probably deemed "Chevelle irrelevant" and not archived. I'll try some searches. Apologize, but I simply dont have the spare time to write it up again right now.
post #34 of 267 (permalink) Old Feb 2nd, 09, 4:34 PM Thread Starter
larry
i called crane corvette he said he could give me a intake without the snow emblem for 1500.00 still way to much
greasemonkey427 is offline
post #35 of 267 (permalink) Old Feb 2nd, 09, 4:41 PM
Fred
Post a WTB ad with a willing to pay price.
I'd also post one on the corvette forum, the HAMB, and any other free to join on line car website.
Ya just never know.
There were almost 4,000 67 tri-power vettes produced. I can't believe the remaining manifolds are all still in use.
Personally, I'm gonna keep trying.
post #36 of 267 (permalink) Old Feb 2nd, 09, 4:42 PM
Fred
I recall typing up a detailed blueprint and posting it here soemwhere, but it was probably deemed "Chevelle irrelevant" and not achived. I'll try some searches. Apologize, but I simply dont have the spare time to write it up again right now.
Any idea what you may have called it? I will ask Al to help us find it.
post #37 of 267 (permalink) Old Feb 2nd, 09, 5:27 PM
I think I used " blueprint" in the title, and my user name was "Gene Chas".
https://www.chevelles.com/forums/show...ower+Gene+Chas
post #38 of 267 (permalink) Old Feb 2nd, 09, 6:09 PM
Fred
Your post and thanks!
Says no HEI. Here's a photo of a tripower and an HEI????
post #39 of 267 (permalink) Old Feb 2nd, 09, 6:28 PM
Yeah, that old winters intake wont stay that clean if you run the car any! I use a small base. I dont prefer the hulk look of HEI's but.. no big shakes.
post #40 of 267 (permalink) Old Feb 2nd, 09, 6:37 PM
Fred
Ya gotta post some "video" of your machine!
As a matter of fact, let's se and hear all of the multi-carb set ups....please!
post #41 of 267 (permalink) Old Feb 2nd, 09, 7:19 PM
For what it is worth, I just missed out on a 69 3 x 2 manifold last weekend by 5 minutes. The seller sold it for $750.00. Also included a original appearing air cleaner lid and base. I posted it in whats it worth.
TC # 529
Never drive faster than your angel can fly...........
69 ss, Garnet Red, Black Buckets, 454(30 over), Richmond 4+1, 2.73 Posi
upstate dave is offline
post #42 of 267 (permalink) Old Feb 3rd, 09, 10:38 AM
Looks like the carbs are too close together to use a metering block on the rear carb, is this correct? Or can you squeeze it in there?
69 Chevelle 496/TH400
ET/Speed - 11.371 @ 117.23 - SOLD JUNE 2017
1965 Chevy Impala 355/TH350 - NEW RIDE JUNE 2017
Georgia69 is offline
post #43 of 267 (permalink) Old Feb 3rd, 09, 11:02 AM
Brandon
I didnt read through this whole thread yet, but saw where someone had mentioned the Barry Grant Six Shooter system...STAY AWAY FROM THAT PIECE OF JUNK!!!!! It is the wost quality I have seen....bad finish, horrible fitment...We sent ours back and checked with Jegs to pull a few from there shelf to see if it was the same, sure enough...P O S !!! They sent back there whole stock on them as well. I have some pictures I will post up later....stay away!!!! Barrys quality went to ****.
Here is a good company to check...however the wait time may be awhile
http://www.hotrodcarbs.com/3deuce.php
1971 Chevelle (LS Swap in process)
ATK HP ENGINES
Notalent is offline
post #44 of 267 (permalink) Old Feb 3rd, 09, 11:10 AM
Bad Brad
Location: NSB Or Daytona Beach Shark Bite Capitol of the World
I started with Nothing and still have All of Nothing!
TC # 2747 ACES # 7166
2009 AACA 1st Place National Junior Award
2009 AACA National Senior Award
ACES Chevellabration Top 3
2010 AACA First Place Grand National Award
1badss396 is offline
post #45 of 267 (permalink) Old Feb 3rd, 09, 1:34 PM
Randy
I don't believe it will fit, the carbs are real close together.
On a side note, the Mopar six-pack air cleaner will fit the Chevy setup (& vice versa). Maybe ole Mopar did a little copying back then? The only other difference is the fuel lines are on the passengers side. Otherwise the Mopar carbs will work.
18 Cruze LT hatchback
03 Suburban 2500 8.1L - Tow Pig
75 MGB - eternal project
03 GSX750F Katana
67 El Camino - Sold
Randy 67EC is offline
This Thread is more than 3566 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
