"71 Chevelle with no spark - Chevelle Tech
post #1 of 3 (permalink) Old Jul 8th, 07, 4:55 PM Thread Starter
Exclamation "71 Chevelle with no spark
We have been working on her for about a month installing a new key swith and and key swith rack and an AC delete kit. During this process we discovered a bad ground. we fixed that and now have a good ground everywhere. here is a list of what we know the problem isn't.
Started (new)
Neutral safety switch (in the right position)
Coil (new) (We have voltage 12.5V across the coil when key is in both the starting and running positions)
Plugs (new)
Plug wires (almost new)
Wiring harness (we have gone over everypart of it)
Man this is kicking our proverbial [email protected]%^
The only thing that we have not, as of today, checked is the electronic ignition (we installed the kit almost a year ago)
If anyone has any suggestions please help, it would be great to drive the thing.
rlbrow03 is offline
post #2 of 3 (permalink) Old Jul 8th, 07, 5:49 PM
Re: "71 Chevelle with no spark
sounds like you have a points type distributor with a conversion kit. put a set of points/condensor in it, see if it works.
Tom Mobley is online now
post #3 of 3 (permalink) Old Jul 9th, 07, 12:01 AM
....or borrow someone's working HEI / wires. It's a quick swap and you'll know for sure.
Pro68Camaro is offline
This Thread is more than 4587 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
