502 BB Chevy Oil Use - Page 2 - Chevelle Tech
post #16 of 18 (permalink) Old Sep 26th, 07, 8:26 PM
Re: 502 BB Chevy Oil Use
Originally Posted by 1st timer View Post
do the new ZZ's with alumninum heads have the same problems as the HO's? I really want to put a ZZ in my 67, but no way am I going to pay the big bucks for an engine that burns oil.....very shameful! guess I will have to go with another engine choice....anybody hear anything about the new Edelbrock 502?
thanks
I can only say that the zz502 crate motor with what looks to be Eddy performer rpm rovals is no oil burner.Maybe we got lucky.It uses 1 qaurt of oil between 5k mile changes.Aside from the weeny HR and the economy 850 VS..we are ok with it.A quick carb swap to a 850 DP and 6 degrees added to the initial timing helped it.It is a tire fryer for sure..and no valve float at 5800 rpm shifts out of the crate.So far so good.
George
8-71 blown 461 Rat on E-85
ironhead is offline
post #17 of 18 (permalink) Old Sep 26th, 07, 11:02 PM
In Memory of Kevin
Kevin
lets see, many of you bought the motor from GM with a warranty, but don't use it? Not a wise move if I may say so myself.... if I buy something, ANYthing, with a warranty, I'll by God use it
Independent shops can do warranty work on GMPP motors. since 3-1-07 they come with a 2 year 50,000 mile warranty.
any concerns should be taken to a local dealer or independent shop. No luck with one dealer, go to another.
Just my take on things though
Some people say I have too much stuff for my garage, I say I have too little garage for my stuff
If some is good, more is better and too much is just right
"When used separately, women and alcohol can be alot of fun...... But when you mix 'em, they'll turn you into a dumbass" - Red Foreman
Old, fat, bald guy is offline
post #18 of 18 (permalink) Old Sep 27th, 07, 9:50 AM
Bryan
I bought my engine long before I started it, let alone put any miles on it.
Bought it in March of 2005, was not even set between the rails for six months---I finally registered the car in June of 06 with only 5 miles on the odometer-----By this time the warranty was long gone.
Do not even think for a minute that I did not argue with GM performance parts AND GM warranty people----They pretty much told me "tough chit"
I bought it thru Summit Racing and installed it myself so the warranty was not worth the paper it was written on (as I gathered from what they told me)
When I finally pulled the engine and got it repaired-----I called them to let them know what the builder found-----They pretty much said, "We don't believe you as a GM technician did not have the opportunity to look at it".
Also having braking issues with a new Ford Ranger and dealing with their warranty people (3 times for brake repairs in 90 days), you can bet I was not very polite to these twits.
Building the 59---I bought parts as I could afford them and in a logical order---when doing the frame and powertrain--the engine to be used is kind of necessary.
Bryan's toyz
66 ElCamino 3oh7/TKO 5spd (mousey) Almost done
On the street now!!!
Bryan59EC is offline
This Thread is more than 4676 days old. It is very likely that it does not need any further discussion and thus bumping it serves no purpose.
Chasing Oil Leak dmg1029 Chevelle Tech 6 May 30th, 06 8:03 AM
BB Chevy Help, oil pressure mac762 2006 13 Apr 7th, 06 6:41 PM
Help!!! Will these holes in the oil gallery plugs hurt oil to the lifters? Whittaker 2006 5 Feb 4th, 06 7:03 AM
So how does an oil gauge work? 67 vette guy Chevelle Tech 9 Aug 2nd, 05 3:48 PM
Fuel in Oil - Low Oil Pressure? Brad 2005 6 Apr 19th, 05 8:39 AM
